10-06-2010, 05:00 PM   #1
live view and focus
I am doing a lot of still life stuff, indoors. I have lights set up, and often i am trying to throw the backgroound out of focus, and keep it dark, while having the objects illuminated. Because I am using the K7 on a tripod, and not usually at eye level, I have got used to using the live view feature. But I cant quite figure out a couple of things.
1 - manually focussing the kit lens isnt very easy in live view, the image is pretty jaggedy and low res when I zoom in and adjusting the focus causes movement in the picture. I have a f1.7 50mm lens as well and focussing is easier, but because of the quality of the picture given by live view it is still hit and miss. I have to check each shot and adjust focuss, take a shot, adjust, readjust and so on until I have the found my focal point. Is this normal, or is there a technique I can employ to help?
2 - There is some kind of gain control going on in Live view, dark parts of the set up cause live view to brighten up, while a lot of light makes the picture darken, which doesnt always help me find focus, is there a way to switch it off?
Graham
10-07-2010, 12:02 AM   #2
QuoteOriginally posted by grayboy Quote
Would it not be easier to use contrast-autofocus with the kit lens? As you are using a tripod on stationary objects, it should be quite good... you can move your focus point pretty much everywhere in the frame in CDAF...
If you hit AE-L in live view, it will also lock the liveview exposure...
10-07-2010, 07:19 AM   #3
Ok - dont knwo what contrast-auto-focus is but I'll dig throught he manaul and have a look at it.
I didnt know that - I'll give it a go. cheers.
camera, focus, lens, live, live view, lot, pentax help, photography, picture, shot, view
How do you use live view? photog Pentax DSLR Discussion 29 03-03-2012 05:40 AM
KX Live view focus issue dehanson1 Troubleshooting and Beginner Help 5 08-07-2010 10:50 AM
K7 live view sdh87 Pentax DSLR Discussion 3 06-07-2010 10:22 PM
How many are using Live View to occasionally focus with philbaum Pentax DSLR Discussion 9 10-27-2009 06:43 PM
Live View - Not getting use to it Rudi Pentax DSLR Discussion 27 11-23-2008 06:56 PM
All times are GMT -7. The time now is 03:18 PM. | See also: NikonForums.com, part of our network of photo forums!
