Originally posted by roscopecotrain Thanks Bert,
i thought UV filter was essential to keep lens safe from dirt and scratches and has no effect on the picture?
the polariser i know effects the picture and is only used on bright sunny days to cut through haze and boost colours so will only be used then.
thanks again.
I know, a lot of people use UV filters for that purpose.
It does protect your lens from scratches, however it has a
negative effect on the picture.
If you do, you need pro grade filters, which are expensive.
A lot of people use their lens hoods for protection, that's why you see so many lens hoods used indoors.
Very, very small scratches on the front element of your lens hardly have an effect on the picture though.
Cheers, Bert
