Originally posted by Rondec He probably meant a graduated ND filter, such that you could hopefully expose for the sky and the skier at the same time.
Those are tough shooting conditions. I would probably dial in .7 to 1 positive EV compensation to try to compensate. You'll end up blowing out the sky, but you'll also reveal more details in the water and the skier. You could also just bring up shadows in post processing.
The other posters are right. Look for good light first. If the light is no good, you will have to do your best and the end results still may not be the greatest...
Interesting point about the graduated ND filter. Personally I would think that it would be too much hassle for a moving subject. But that's just IMO.
Originally posted by vladm11 Thanks for a good example, I will try play more with the position. In my case it is easier to move the subject (me) than the camera position, because I was using an intelligent remote camera control - my wife :-)
What kind of lens you are using? I saw some of your shots were done with 400mm.
No worries.
If your wife is going to stay in one spot, I agree it would be a good idea to try moving your position relative to her and the sun. See what happens
I was using the old M series 400mm lens listed in my signature. More reach than the 55-300, but manual focus and exposure. Saying that, it's still quite straight forward to use. The 55-300 is a more than capable lens though. I might suggest asking your wife to try going out to the full 300mm length and shooting around f/8. JHD has a fair point too.
good luck!
cheers
