10-11-2010, 06:16 PM   #1
DaveHolmes's Avatar
Screw-on-Fisheye attachment lens
I realised that at the moment there's no way I can afford a 10-17mm Fisheye
So (even having read how bad they are...) I bought myself a 50 screw-on type affair...
Here is something I've noticed for those who may be considering....
Wide open (f3.5 on kit-lens) the edges are VERY soft... but at f11 (actually from f8) the results are fairly promising
For a 'just a bit of fun' cheap alternative (while I save!!) to a real fisheye lens its really not that bad!
10-12-2010, 06:43 AM   #2
mike.hiran's Avatar
could you post some samples? I used to use one of these on my canon P&S and it was fun to play with. in the pentax mount, some cheaper but good options are the zenitar 16mm f2.8 and the Rokinon FE8M-P 8mm F3.5 Fisheye Lens for Pentax. The latter I think is available in other brands like samyang and a couple others I believe.
10-12-2010, 11:46 AM   #3
RioRico's Avatar
QuoteOriginally posted by vagrant10 Quote
Samyang makes the 8/3.5 and it's rebadged as Rokinon, Vivitar (I think) and others. It ain't that cheap but it's apparently a good performer. The Zenitar is pretty fishy on FF but only moderately so on an APS-C dSLR, with the same characteristics as the DA10-17 @16 but 1.3 stops faster. All of these are frame-filling rather than full-circle fisheyes. Then there's the 12/8 badged as Vemar and others, which on FF is full circle but not 180 (with it circular lens hood) and on APS-C is frame-filling and pretty damn fishy.
For full-circle, I can't recommend anything modern 'cause I just don't know enough about what's available, but I do have fun with an old Kenko 180 Degree FE adapter. Mounted on an 18-55 or 28-80 @ ~40, I get a full circle on an APS-C frame. But for anything like edge sharpness, I need an aperture of around f/40. Slow and steady...
10-12-2010, 02:10 PM   #4
DaveHolmes's Avatar
Here are a couple from the last couple of Day's...
camera, fisheye, lens, pentax help, photography
For Sale - Sold: Vivitar 100mm f/3.5 AF Macro Lens with 1:1 filter attachment wallyb Sold Items 0 12-16-2009 10:30 PM
Just a thought : Using DA* lens as Screw Driver Lens instead of SDM mcjm78 Pentax SLR Lens Discussion 0 03-21-2009 08:40 AM
Lens Aperature Screw Up DivinusAssassin Photographic Technique 11 09-03-2008 08:09 AM
Attachment lens roy Pentax SLR Lens Discussion 3 02-07-2007 08:49 AM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
