10-12-2010, 04:14 PM   #1
DaveHolmes's Avatar
Bracketing?
It could be that I'm being thick... But this is the beginners corner so...
What is actually meant by the term 'bracketing'?
10-12-2010, 04:16 PM   #2
jimH's Avatar
QuoteOriginally posted by DaveHolmes Quote
doing one or more exposures above and one or more exposures below what the camera light meter calls for.
10-12-2010, 04:33 PM   #3
DaveHolmes's Avatar
QuoteOriginally posted by jimH Quote
Oh good... Appears I already do that
10-12-2010, 04:35 PM   #4
DaveHolmes's Avatar
Now I vaugely understand what people are talking about on the 'stop down metering' thread!
Cheers Jim
10-12-2010, 04:52 PM   #5
jimH's Avatar
Cheers Jim
You can also do it with automatic lenses, by settings on the camera that use multiple exposure settings too and by setting your EV steps in your menu.
10-12-2010, 05:30 PM   #6
Dave: bracketing and stop down metering are different.
Not sure which camera you are using, but most have a bracketing option of either 3 or 5. You can bracket in P mode, but if you want to maintain the shutter speed, bracket in TV (f-stop will change). If you want to maintain f-stop, bracket in AV (shutter speed will change)
In your Custom menu, you also should be able to set your EV bracketing parameters. 1/3, I believe is the factory preset and is what I use. Not sure. I may have set to that. At any rate, I find sensors much more sensitive to exposure differences than film, so I like 1/3.
If you set bracket at 5 and EV at 1/3, you will get one regular, one -1/3, one -2/3, one +1/3 and one +2/3.
10-14-2010, 01:57 AM   #7
DaveHolmes's Avatar
Thanks Ron.. Yeah I got that bit:-)
I've been manually bracking for ages it seems (ie; taking the same shot 3 time and then using metre to take shot again slightly under and over exposed) but found the Drive mode braketting (not sure how I missed it for so long!!) and is a big help that'll save oodles of time!
Cheers!
Bracketing: other than EV Bill L Troubleshooting and Beginner Help 9 09-25-2010 06:00 PM
Exposure Bracketing on the K-x noahpurdy Troubleshooting and Beginner Help 7 12-26-2009 10:28 PM
K110d and Bracketing warrenstilwell Troubleshooting and Beginner Help 4 11-24-2009 08:31 PM
auto bracketing jnoelle Photographic Technique 19 05-09-2008 10:23 AM
Bracketing Ed in GA Photographic Technique 14 06-26-2007 09:04 PM
All times are GMT -7. The time now is 10:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
