10-15-2010, 08:49 AM   #1
netuser's Avatar
UV filter stuck on lens
Hi all
So, it seems I have a 77mm hoya UV filter stuck on my tamron 70-200/2.8.
Any ideas on how I can take it out gently?
Thanks in advance
10-15-2010, 09:11 AM   #2
QuoteOriginally posted by netuser Quote
Hi all
Thanks in advance
Take a tie wrap and cut off the little locking tap then wrap the tie wrap around the filter and turn it .
10-15-2010, 09:21 AM   #3
netuser's Avatar
QuoteOriginally posted by Ken T Quote
Will give it a try tonight Thanks
10-15-2010, 09:24 AM   #4
You know the rubber "grips" they sell for taking jar lids off?
woof!
10-15-2010, 09:35 AM - 1 Like   #5
Try gently pressing the front of the lens down onto something like a piece of rubber or leather that's flat on a table or work surface, then rotating the lens.
Often it's the slight distortion that occurs when applying pressure to the sides of the filter with your fingers that causes it to stick; applying pressure to the whole front of the filter doesn't cause the same distortion.
10-15-2010, 09:36 AM   #6
netuser's Avatar
Three nice ideas
Thanks
10-15-2010, 02:33 PM   #7
Nowhere Matt's Avatar
Does the filter say "UV-R" on it somewhere?
Theater Of Noise-Ricoh UV Filter
Sorry. It had to be told.
10-16-2010, 10:45 PM   #8
Get yourself a pair of latex dipped/coated work gloves.
10-18-2010, 07:04 AM   #9
netuser's Avatar
Tie wrap worked perfectly and gentrly.
Thanks all
10-18-2010, 08:40 AM   #10
Lowell Goudge's Avatar
try filter wrenches
there are specifically made filter wrenches you can get to remove filters from lenses or separate stacked filters that are stuck
also there are strap wrenches that are used for opening bottle lids
camera, filter, pentax help, photography, uv, uv filter
Filter stuck on lens. Suggestions? Zeroset Pentax SLR Lens Discussion 50 03-21-2012 07:45 PM
stuck lens filter widget Nass Photographic Technique 17 04-11-2010 06:32 AM
Help! Filter stuck on lens. Spock Pentax SLR Lens Discussion 14 11-24-2009 11:05 PM
Stuck filter, help please! jadem Pentax SLR Lens Discussion 5 05-06-2009 07:29 AM
Filter stuck in reduction ring rience Pentax Camera and Field Accessories 4 02-08-2009 08:20 AM
All times are GMT -7. The time now is 10:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
