10-19-2010, 05:43 AM   #16
adwb's Avatar
QuoteOriginally posted by flyer Quote
That's basically wrong. Your printer and screen (some can, but they cost quite a few thousands $) can't reproduce the full aRGB spectrum. You should work with sRGB when working with consumer printers and screen. Working with aRGB and ooutputing in sRGB ends up with dull looking pictures.
I suppose it depends what you do that works for you so only you know best, however, its not what the printer supplier [Epsom 2880] , paper suppliers and ink suppliers I use tell me.
Further there is a very marked difference in the colours when using a aRGB colour space all the way through or at least in my case there is.
10-19-2010, 06:06 AM   #17
wlachan's Avatar
QuoteOriginally posted by Silverkarn Quote
Well, ok. So its my monitor. And i'm not looking at the histogram correctly. What should i be looking for, and how do i calibrate my monitor?
EDIT: ok, so upon further investigation i noticed that when looking at the monitor at a lower angle the image looks like the photo printed, so i messed with the contrast and brightness settings until the printed image and my screen match up.
You are using a TFT LCD, that's why the brightness changes due to different viewing angles. IPS LCDs are best for photo-editing. To properly calibrating the monitor, you will need some hardware solution like i1D2 or Spyder3 etc. There is simply no other way if you want accuracy.
10-20-2010, 06:10 PM   #18
QuoteOriginally posted by adwb Quote
There should be a difference. Your screen can't show the full aRGB spectrum, and your printer can show slightly more than your screen. When you're processing your pictures in aRGB, you lose quite a bit in the dark blue and deep red end, so your pictures are going to look lighter than sRGB, but they won't look better than what you could get with sRGB and a good calibrated screen and printer.
10-20-2010, 09:00 PM   #19
SpecialK's Avatar
Here are a couple free online calibration aids. I use the first one.
http://www.jasc.com/support/kb/articles/monitor.asp
Display Calibration - DisplayCalibration.com - Calibrate your computer display or monitor online for optimal viewing. Brightness, contrast, color depth, resolution and freeware software downloads.
Photo Friday: Monitor Calibration Tool
camera, pentax help, photography, photos, print
What's the largest size I can print photos from k-x? hockmasm Pentax DSLR Discussion 11 05-05-2010 12:04 PM
Pricing individual photos for internet/print use deadwolfbones Photographic Industry and Professionals 4 04-08-2010 12:00 PM
Where to print photos? Javaslinger Digital Processing, Software, and Printing 16 11-02-2009 08:14 PM
Dark photos catt410 Troubleshooting and Beginner Help 5 07-03-2009 10:06 PM
Where do you print your Photos? Alvin Pentax DSLR Discussion 28 01-23-2007 11:37 AM
All times are GMT -7. The time now is 01:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
