Originally posted by Stiv Got any examples of using this? I've ordered the cheap diffuser from eBay so if it turns out to do nothing I'll start the hunt for a film canister!
Probably cheaper to buy some cheapo Fujicolor (or ask at a local shp that still has a minilab) than have me send you one, but I recently dug up a few more here.
Someone else here had a clever little design, too, (Sorry, someone else! I can't recall!
) involving a flat sheet of plastic with a matte surface: he used disposable cutting board material, but I find the same stuff in some fish packaging now and again: the idea is you cut a tab to fit in your flash shoe, then cut the rest so you can bend it around and have it tuck into the popup flash's nest. You get basically the same thing as the film can, only it can be bigger and it stores flat.
