10-20-2010, 07:43 PM   #1
Dirt cheap diffuser
Hi all,
I'm planning to get myself a good quality external flash in a few months but in the meantime I'm looking to make the most of the built-in flash on the K7.
I've had a crack at all sorts of home-made solutions with varying levels of success (the 45 degree business card worked the best indoors). But it would be nice to have some kind of simple diffuser that would stay on when I'm outside in the wind.
I've found this on eBay:
3-1-Puff-Pop-up-Flash-Diffuser-Fr-Pentax-K-7-K-X-K-m
Has anyone had any experience with these? It's only a few dollars so I'll probably just give it a crack regardless unless someone has used one and found it does absolutely nothing.
10-20-2010, 08:02 PM   #2
KxBlaze's Avatar
I do not have personal experience with these but have heard they are pretty good and for the $ you cannot go wrong.
A free option is to find/get a white (clear/almost see through) film canister, cut out a rectangle (measure the pop-up flash for the exact dimensions) and put the canister over the flash. This is what I do with my flash and it works really well.
10-20-2010, 08:57 PM   #3
I've heard of people using those. I've heard they work well. Never used one myself, like KxBlaze.
To diffuse light WELL, the best way is to make the light source bigger. You can shoot through a diffusion material like this device, but the best way is to bounce it off a wall or ceiling (short of using a softbox).
Cost: free.
Or if you're outside, use the sun. A few white foamcore boards to bounce light up from the sun to the subject work extremely well. Black foamcore works well to reduce light.
10-20-2010, 10:00 PM   #4
Thanks for the tips guys.
The old film canister trick sounds more wind friendly than my attempts but I can't say I've bought film any time in the last 10 years... So I might give this cheap diffuser a crack.
10-21-2010, 01:36 AM   #5
RioRico's Avatar
Another cheap trick:
Use the thinnest infant's sock you can find. Or a translucent condom.
10-22-2010, 03:53 PM   #6
Ex Finn.'s Avatar
Would the one with ribs give you an uneven illumination?. Or could it be used for creative lighting effects?.
10-23-2010, 05:45 AM   #7
RioRico's Avatar
QuoteOriginally posted by Ex Finn. Quote
Hmmm, I haven't kept up with condom technology lately. How about translucent models with faces? Back in the day, were Dick Nixon rubbers... but they were opaque.
10-23-2010, 07:12 AM   #8
Pablom's Avatar
I have one of these, it works well but it really decreases the flash's power, which is already not very much, so it is very limited in use.
I don't have any use for the different colors either.
10-23-2010, 08:45 AM   #9
Senior Moderator
Parallax's Avatar
Not sure about the uneven lighting, but if there are two flashes involved, it may trigger the other one more reliably.
10-24-2010, 01:39 PM - 1 Like   #10
Jasvox's Avatar
several tricks to consider....you can cut a ping-pong ball to fit over the pop-up flash like a "Smelfin" type, you can cover the flash with a coffee filter, you can cut out a bounce from card stock and covered in smooth tin foil and attached at a 45 degree angle (FinnBounce), rolling paper over flash, etc...never used a condom though.
The FinnBounce and the Smelfen
The DIY FinnBounce
Jason
10-24-2010, 04:53 PM   #11
Ex Finn.'s Avatar
I forgot to add "".
10-24-2010, 05:50 PM   #12
Take one pair Sheer Energy white hose and one rubber band. Cut toe off one leg of hose and secure over the flash with the rubber band. Instant diffuser.
Warning for the guys: Do not use your wife's new pair of of white hose. She will not be any happier with you than my wife was with me.
CW
10-24-2010, 07:09 PM   #13
QuoteOriginally posted by Stiv Quote
Hi all,
I got one JUST like this from Ebay, except without the blue and orange filters. I got it just because i was to take some photos of the family this coming thanksgiving and christmas and i dont have a regular flash and/or a diffuser/deflector. It makes the flash marginally softer, enough that i can use the pop-up flash for family photos in darker rooms.
10-24-2010, 07:33 PM   #14
Eruditass's Avatar
Ah, I made a cardboard thing with foil on it just like the finbounce. Works pretty well.
QuoteOriginally posted by Silverkarn Quote
Have any samples?
10-25-2010, 12:39 AM   #15
QuoteOriginally posted by Eruditass Quote
Have any samples?
Well, i just read this message at 2:30 AM i will try to get some samples tomorrow....... i mean today >_> after i get some sleep.
camera, crack, diffuser, flash, pentax help, photography
DCL (dirt cheap lens) Club whitedogone Lens Clubs 173 11-23-2019 03:55 AM
A tele between dirt cheap and crazy expensive? mutedphotos Pentax SLR Lens Discussion 32 04-19-2009 07:57 PM
Dirt cheap K20D Big Dave Pentax DSLR Discussion 7 10-08-2008 09:52 PM
For Sale - Sold: Close-up Lens and Assorted Filters for 49mm Threads - Dirt Cheap! GaryML Sold Items 1 04-21-2007 01:19 PM
All times are GMT -7. The time now is 04:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
