Originally posted by powdablu21 Military oriented. USAF Thunderbirds and Im sure plenty of other military planes. Many vintage military planes with be there. The website is wingsoverhouston.com
Very cool. Your lens at 200 should be able to do the job, and here are my hints:
1) Chances are, they're going to drop some parachutists. If you can get as close to the landing area as possible--which won't necessarily be the best viewing for other stuff--be there when they come down, but don't bother shooting until they get close.
2) There's usually a schedule telling you when and where things will be happening.
3) Be ready for +1, +2 Ev all day. Otherwise, you'll be metering for too bright a sky, or white clouds.
4) If you want to ignore #3 above, and depending on the color/tone of the plane, this might be the time to use Spot Metering--and lock it in if you're shooting in Av mode.
5) If they have aerobatic biplanes, resist the temptation to click too early. Wait until they're at the very top of their altitude and they "stall" before coming down. That's when they're at their slowest and you can capture them the sharpest.
6) It's going to be tricky selecting ISO to match the shutter speeds and aperture you're going to want, but definitely set ISO manually. Also, shoot everything at the sweetest sharpness your lens can muster, or just stop down two stops. You're going to be shooting stuff at a far distance, and DOF ain't going to be much of an issue, so 5.6 or 8 should do you all day. If it's a sunny day, I say just set it at 400.
7) The Thunderbirds (I've seen them several times at the Ft. Lauderdale Air and Sea Show) are trained to look beautiful from the ground, and they don't fly half as fast as you would imagine and make for some beautiful shots. Your best ones will be with your lens at the WIDER end, getting them all in frame when they're closest to you.
8) If you don't bring a polarizer, don't bother going.
Have fun!!!
