10-22-2010, 12:58 PM   #1
SMC FA 50mm 1.4 question
HI All,
I have just bought a SMC FA 50mm 1.4 and I noticed something strange. The lens is working just fine, however to me it seams the aperture ring doesn't work or probably I'm missing something here. If the lens is not attached to my K-x the aperture ring is working and I can see the blades closing and opening. However when I attach it to the K-x the aperture blades are fully opened. I believe this should be fine as well. Shooting in Automatic aperture works fine, but when I decide to use the aperture ring and to set manually some aperture all photos are anyway made @ 1.4.
Could you please advise if that's a correct behavior?
Thanks,
Tiho
10-22-2010, 01:01 PM   #2
If the Kx is anything like my K100DS you will need to enable the use of the Aperture ring through a custom setting in the configuration menu.
10-22-2010, 01:01 PM   #3
wlachan's Avatar
This is normal because Pentax dropped the aperture ring since the digital era. However, Pentax DSLRs still allow the use of aperture rings though the custom menu setting.
10-22-2010, 01:08 PM   #4
Excuse my stupidity I had the use of the aperture ring set to on but wasn't shooting using the Manual Mode
Cheers
10-22-2010, 01:16 PM   #5
pschlute's Avatar
If you are using a lens with an "A" setting on the aperture ring, leave it set to "A" and use the camera dials to set the aperture. This way you will have full exposure control the same as with a DA lens.
10-22-2010, 03:21 PM   #6
QuoteOriginally posted by tichomir Quote
Cheers
Once you take the lens off of A, in anything but manual mode (M), the lens will shoot wide open regardless of the aperture ring setting.
10-22-2010, 11:41 PM   #7
thanks for the suggestions guys. everything clear now.
50mm, aperture, blades, camera, fa, k-x, lens, pentax help, photography, smc, smc fa 50mm
For Sale - Sold: K-mount Tamron-F 2x Pz-AF BBAR MC7 TC, TWO 50mm SMC-M F1.4, and a 50mm SMC-A F pxpaulx Sold Items 11 06-14-2010 07:42 AM
Asahi smc 50mm F/2 question kyubi01 Pentax SLR Lens Discussion 1 02-23-2010 12:12 AM
Pentax SMC DA* 16-50mm question Burgerbrater Pentax SLR Lens Discussion 14 09-28-2009 07:05 PM
For Sale - Sold: SMC 50mm, SMC 50mm, Tokina RMC 28mm bri_n_m Sold Items 3 06-20-2009 12:27 AM
Question about old 50mm SMC A 1.7 Hannican Pentax SLR Lens Discussion 2 12-13-2007 09:57 AM
All times are GMT -7. The time now is 11:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
