If you are looking for what's new with the update, you could check the release information.
There has to be a pdf somewhere saying what they changed in the new release
If you're speaking about firmware version 2.02, here's the documentation:
istDS FW2.02 Update .doc
Oh well, nothing else to do right now, so I put it here also
Changes to V2.02 --- Addition of compatible SDHC Memory card
Changes to V2.01 --- Support for SDHC Memory cards.
Caution : Only istDS users are permitted to download the firmware update.
Changes to V2.00 The following function were added in version 2.00
1. Continuous AF" mode has been added to the AF settings in the Record Mode menu and AF.S /AF.C can be selected in the Menu
2. Auto Sensitivity has been added in the sensitivity mode
3. AE-L button on M has been added in the Custom menu.
4. The effect of Digital soft filters can be selected from weak, middle or strong
5. Dutch and Swedish languages has been added to the language
6. The sample picture will be displayed in the LCD monitor when select picture modes
7. For prevent the confusion, the item that was not able to be set by the menu, made a gray character.
How to operate the additional function, Click here
Change to V1.02: • Correspond to the SD memory card greater than 1GB, also Version 1.02 include the additional function which was released at Version 1.01.
Change to V1.01: • At the long time exposure situation such as astronomical photography, green noise might be generated partially on the image when the noise reduction is turned on.
This phenomenon only occurs rarely under special shooting condition such as starry sky, and will never occur at the general situation that we are assuming.
The version 1.01 will minimize this phenomenon as much as possible for the customer who use *istDS for this purpose.
