Originally posted by JeffJS How fat is your wallet and how much lens do you want to carry around and how often do you want to swap them?
Though not weather sealed, you can get an 18-250 for less than the 18-135. I'm betting the image quality isn't going to be THAT much different, and the 18-250 is available now.
Google
The 50-200, in my opinion, is a doorstop. Never wide enough and never long enough and the image quality (from the one I had) is good at best. The only thing you gain with it, again, IMO, is the weather sealing on that version. Take the money you save buy buying the 18-250 instead of the other two lenses, and invest in an ultra wide zoom. 12-24, 10-17, 10-20 etc OR go prime with the DA15 Limited or DA14. If you need longer reach later on, get a 300(+)mm prime. A lot of options, you have plenty of time, none of the currently available lenses are more than a week away.
That's my rambling opinion. Lowell gives some pretty good advice as well, we're just different. My actual preference is for Prime lenses.
I planned on spending approximately $2500 or so on lenses/filters in the few months following November (after I get the K-5), maybe a little earlier. So that's how skinny my wallet is, lol. When hiking, I'd rather not cary more than two (one in bag, one mounted) med/lrg lenses, unless the third is small and has a good reason to come along. For a good portion of my hikes I'd prefer not to swap at all, but I plan on changing up the pace/type of more of my hikes so swapping shouldn't be as much of an issue (except for possible dust, etc).
I think the 18-250 sounds good but I'm really concerned about using it in harsh weather if it's not weather sealed. Are there any similar FL options that are weather sealed?
Earlier I mentioned the 35mm @2.8, but maybe I should go with the 31mm @1.8 instead? Then add the 50 @ 1.4 after that, followed by a DA15 or 14?
So basically, I'd really like either one or two zooms that cover 18'ish to somewhere at or over 200mm, but that are weather sealed. They'll be the ones I use in bad weather (rain, snow, dust, etc). Maybe that's asking too much though?
@Lowell - What's CBA? I wish I could afford multiple bodies, haha. I could keep my K-X but it's not weather sealed so I probably wouldn't ever use it unless the K-5 broke, lol.
