11-01-2010, 05:35 PM   #1
Date & Time Issue
My time is set to 24hr mode. And when I imported my pics they show ie: 8:30 am, when they were taken at 8:30 pm.
If I change to 12hr mode, it only show the AM setting. This is probably silly, but can anyone explain this to me?
11-01-2010, 06:51 PM   #2
SpecialK's Avatar
What do you mean "imported". What software are you using to view the exif?
11-01-2010, 08:41 PM   #3
I'm using Aperture 3
11-01-2010, 11:00 PM   #4
Either your camera or your computer is 12 hours off. Or your Aperture doesn't understand a 24 hour clock. What does the camera say when you review a photo? Is it correct?
11-02-2010, 05:43 AM   #5
Lowell Goudge's Avatar
date and time is a display function only, it is stored in an absolute value in the image.
What can happen with "import" functions is that the software might just put a new date and time on the file, representing when it was imported.
That is still not an issue, because the date taken info is stored in the exif data but it does confuse things when looking for a file with explorer. This also happens when using a cable to download, which is why I always take the card out of the camera and use a card reader.
11-02-2010, 09:03 AM   #6
QuoteOriginally posted by ladyteri934 Quote
Just add 12 hours to whatever time it's set to right now.
11-02-2010, 03:05 PM   #7
Thanks everyone. I haven't figured it out yet, but I have confirmed that the time showing in Aperture, is the same time shown in my camera, it's just that all pics show AM when it should be PM. It's like there's no option in the camera to change the time to PM. When you set the time, the only option is am.
11-02-2010, 07:01 PM   #8
ChipB's Avatar
If I remember correctly, if you are setting the time to a PM time, you have to set the time using the 24 hour format - ie: 6 PM would be 18:00. Then, when you select the 12 hour display format the time is correct. Hope that makes sense.
11-04-2010, 04:04 AM   #9
PinarelloOnly's Avatar
QuoteOriginally posted by ChipB Quote
I agree this is probably the problem. Not understanding that 8:30 pm is 2030, which the camera should display in 24hr format.
camera, date & time, mode, pentax help, photography, time
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
Quick question: burning time & date info on a photo brkl Digital Processing, Software, and Printing 2 05-21-2009 03:34 AM
Optio M50 Date & Time stamp MarkC Pentax Compact Cameras 1 04-30-2009 03:30 PM
A30 not holding date & time?? lmhcralph Pentax Compact Cameras 3 01-18-2008 08:25 PM
Date & Time Resets *ist DL cooper0413 Pentax DSLR Discussion 5 11-20-2007 04:41 PM
All times are GMT -7. The time now is 09:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
