Originally posted by excanonfd Scratching up the finish on the TC so that the contact on the body mount touches is sufficient? What about moving the seventh pin on the TC to the correct position?
I'm not sure what you mean by "moving the seventh pin on the TC to the correct position." To me, scratching the base of the TC (or extension tube) to ground the seventh pin is sufficient.
The seventh pin is used to transmit focal length, distance to the subject, exact absolute f-stop value, lens size, and MTF data from the lens to the body. With the TC or the ET between the lens and the body, the focal length, f-stop, and lens size data, if exist, are incorrect any way. Grounding the pin won't be any worse than transmitting incorrect data.
