Originally posted by Steve Beswick If an extension tube, teleconverter, or lens is "pin locked" on any autofocus Pentax body, 99.9% of the time that means that the Ricoh pin on said lens is jammed in the AF drive mechanism hole on the body.
Not necessarily. Or maybe I'm just lucky....
One some Pentax p-KA/Ricoh lenses/TCs/ETs, the "Ricoh pin" is actually a ball, or a pin with round head. It does not get stuck in the AF drive hole at all.
I have a copy of "proper" ET (left in the photo below) and 3 copies of ex-TC ET (right in the photo). They all have the infamous "Ricoh pin." I use them as is on Pentax DSLRs, none of them get stuck.
Originally posted by excanonfd You have a 12mm extension tube from the AT-23 set and the 2x TC converted to ET. Comparing the two, is there any difference in the exposure accuracy between the AT-23 ET and the TC-ET? If there is no difference, then simply grounding the pin is sufficient but if the AT-23 is more accurate then there is a seventh pin on the TC-ET located about 1cm left of the scratch mark point that can be moved to the grounding point. There is no contact at that location on the Pentax DSLR body, so I am assuming that the pin can be relocated without consequences.
I tested the 7-pin ET and the 6-pin ex-TC ET (7th pin is grounded). In terms of the exposure accuracy, I could not detect any difference. For the test, I used a K7 body and a DA Ltd. 70mm lens.
Originally posted by excanonfd What about moving the seventh pin on the TC to the correct position? Your thoughts would be appreciated.
I did some more tests and found something I had never expected.
The bodies I used were K10D (firmware version 1.30) and K7 (firmware version 1.1). The result was the same with either body.
The lenses I used were DA* zoom lenses with SDM: 16-50, 50-135, and 60-250. The result was the same with any of them.
- With a 6-pin ET, the operations were normal as expected: the camera treated the combo as if there were an A-lens attached.
- With a 7-pin ET, things became interesting:
- When I hit the "Menu" or "Info" button, the LCD screen flashed and then turned itself off. There was no way to view the info or change any setting in the menu. Even when the memory card was full, the message "Memory Card Full" flashed once on the LCD screen, then turned off.
- With the body in AF-S and the lens in AF, pushing the shutter release button did not do anything. In other words, there was no way to release the shutter.
- With the body in AF-C or MF, or the lens in MF, the shutter might or might not release, depending on the focusing of the lens. What was even more interesting was that the shutter could release when the photo was NOT in focus, but the shutter did not release when the photo was in focus.
- There was no focus indicator (red LED) lighting up in viewfinder. There was no focus confirmation (green hexagon) in viewfinder display.
Please note that this was not a case of equipment failure. The symptoms were the same for either camera body, any DA* lens. When I masked the 7th pin of the ET with a piece of aluminum tape (essentially grounding it), the ET operated like a 6-pin version.
Based on the result of my experiment, a 6-pin TC/ET is more desirable than a 7-pin version.
