(I actually
posted this entry on Steve's at the end of a lengthy discussion about what to get once I got my K-x. )
I got the K-x with 18-55 and 50-300 lenses kit back in September. Since it was my first DSLR, it meant, of course, that there was always something more to buy to complete the outfit. Being on a rather tight budget, I did a lot of research and shopping around. Here's my final outcome.
I have also provided links to the places where I bought the accessories. You'll be hard pressed to find them cheaper, and I've been happy w/ the quality and functionality of all the ones for which I've provided links. Prices include shipping.
- K-x with 18-55 and 50-300 lenses kit (Price has since gone up at BH, but their prices seem to fluctuate daily. In general, their prices have been better than anything on Amazon. Btw, I have learned to denote it as K-x so as not to confuse it with an old Pentax film camera called a KX)
- Got hoods for each from eBay: for the 18-55 and 50-300 (~$10 each)
- Got a couple of lens cap keepers for $1 each
- Got the Giottos Cleaning Kit w/ blower and brush from BH (~$12)
- Already had tripod and monopod (but they will probably need to be upgraded some day since they were both fairly inexpensive ones. I do find I use the monopod a lot, and it is a great help just for stabilizing normal shots.)
- The Pentax neck strap is fine, but it seemed to be in the way a lot of the time, so I got an Op/Tech Wrist Strap from BH. This is what is on the camera most of the time now, and I like it.
- Found a remote control for the camera for $2.57 on ebay that works fine
- After much researching, I ended up buying a Bower SFD926P flash (~$105). The head tilts and turns and has Autofocus TTL Power Zoom and has a built in reflector and diffuser.
- I needed to get some more batteries. Eneloops come highly recommended, but I ended up getting 8 of these comparable (ie, like the Eneloops, they retain their charge longer while stored) Rayovac Rechargeable Hybrid NiMH Batteries for about $17 at Amazon
- Picked up another SD card - a Transcend 16Gb Class 10 (!) for only ~$25 at Amazon (Transcend is regularly recommended as a reliable card)
- I spent a lot of time looking for a camera bag. I decided I wanted a sling bag. I really liked the Case Logic 205, but no one seemed to have it in stock. (It is now in stock at BH for ~$56) It's a pretty compact bag, so I ended up getting something that's a bit larger, the Lowepro Slingshot 202 AW. (You may be able to get it a bit cheaper if you want to try bidding on ebay, but get it immediately for ~$65 here on ebay)
That really provides for a complete outfit, but...
Okay,
I really love the 50-300mm lens, but I find the 18-55mm somewhat more challenging. I need to work harder at getting a sharp pic, and I find that for truly sharp images, it really needs to be stopped down to F8 or more. After poking around this and the pentax forum, it appears that one really might be better suited with a fast prime. So... because I need to keep this as cheap as possible, I've been doing some 'bottom fishing' on ebay. I found a SMC-Pentax A 50mm 1:2 for ~$20 on ebay. For that price I will be keeping it. It isn't necessarily sharper, but I can shoot at F2 or 4 w/ decent results. The lens that is more often recommended is a 50mm 1:1.7. Again, I'm working cheap, and I just recently won (but have not yet received) a SMC Pentax-M 50mm 1:1.7 attached to an old Pentax ME camera for ~$33. I'm hoping that will serve as my 'family portraits' lens. (The A lens w/ manual focus is quite easy to use. I'm hoping that this M lens and the green button will be just as easy.)
BUT, since the APS-C sensor has a 1.5 crop factor, to get something closer to a 50mm equivalent on a 35mm, I'm still poking around for an old 28mm 1:2.8. Those seem to be harder to find.
So, all told, I'm in for about $900, but I think I have a really decent DSLR outfit. The family is glad to have all their birthday and Christmas shopping for me already completed!
If anyone else has suggestions for inexpensive upgrades, I'd be happy to hear them.
