Originally posted by tcwilson Thanks for the information. If the camera really combines pixels via software to get the resized image that raises an interesting question about noise, since the pixels are analog sensors.
I know an electrical engineer could straighten me out on this, but here's my theory. For the sake of example, we set the camera to produce a 6 mp image instead of 12mp By combining two real pixels into the new single "virtual" pixel" you would double both the signal and the noise. So the S/N ratio would remain the same. But since you have now doubled the total signal, you can attenuate it lower, also lowering the noise below the threshold of detection.
Now in experimenting with the different settings, this clearly isn't the case. But if engineers could figure it out, it would be neat trick. Just imagine the low light response you'd have at a 2mp setting.
And that's pretty much what you get when you downsize your image (in Photoshop or whatever) to 1000-pixels wide, the noise doesn't appear to be "as noisy"
The camera most certainly uses a similar process (software algorithm) to downsize the image prior to saving it on the card.
