11-04-2010, 11:32 PM   #1
K-X flash strength?
Is the Pop-Up flash of the Pentax K-x adjustable in brightness? I could have sworn i was reading two people talk about that on the forums before.....
11-05-2010, 06:19 PM   #2
KxBlaze's Avatar
I'm pretty sure this is not an option on the Kx because I have read the entire manual and have never heard anyone talk about it.
*Maybe someone hacked the software or even the hard wires to do so.
11-05-2010, 06:24 PM   #3
Raylon
Guest
From Pentax:
Q: Can the flash output of the K-x be compensated?
A: Yes, the output of the built-in flash or a PENTAX external flash can be adjusted in the range of -2.0 EV to +1.0 EV. [Status screen > Flash Mode screen].
11-05-2010, 06:28 PM   #4
QuoteOriginally posted by Silverkarn Quote
Hi Silverkarn,
I'm not sure what you mean, but if you want to adjust the normal P-TTL exposure, you have Flash Exposure Compensation (normally -2 to +1 Ev) in the flash menu and you can probably double up with the regular Ev Compensation (IIRC -2 to +2 Ev -- I don't have a Kx so I'm not sure). I know that I can use both in at least my later Pentax bodies.
Use (-) Flash Ev or Ev comp to lessen the flash's exposure and (+) to brighten it.
If you get inconsistent flash exposures, try using a fixed ISO. Also try setting the AF to lock with AE in your custom menu. P-TTL flash with the popup should be pretty accurate for what it is.
Scott
11-08-2010, 08:13 PM   #5
KxBlaze's Avatar
QuoteOriginally posted by Raylon Quote
From Pentax:
I guess I missed that part. But thats good to know. I'm gonna try that.
11-08-2010, 08:18 PM   #6
Docrwm's Avatar
I've found it very nice to be able to dampen down the flash to use it as a lower level fill at higher ISO. In several shots it has brightened the face in a darkened room without lighting up the entire room. Very nice feature.
11-09-2010, 08:04 AM   #7
DaveHolmes's Avatar
QuoteOriginally posted by Docrwm Quote
Its about the only nice feature of the flash... Set anywhere up from -1 it looks horrible!
11-09-2010, 08:20 AM   #8
Pablom's Avatar
QuoteOriginally posted by DaveHolmes Quote
you can use a diffuser
11-09-2010, 08:23 AM   #9
Eruditass's Avatar
QuoteOriginally posted by Pablom Quote
Or bounce it on a wall or ceiling with a mirror. On-axis flash other than light fill flash sucks pretty bad.
11-09-2010, 08:27 AM   #10
Ananta Androscoggin
Guest
I'm almost all the way through the K-x manual, and apparently I missed that part when I read through the Flash section.
Glad to know about it, and thanks.
11-09-2010, 09:10 AM   #11
Docrwm's Avatar
Perhaps I am not as discerning but I find the flash on the K-x to be a very solid performer. No, it's not as good as bounce flashes, remotes, etc., etc., and natural light is always my preference but there is nothing wrong with it IMHO. It's a pop-up built-in flash and for what it is its performance is absolutely fine.
11-10-2010, 01:39 AM   #12
From Pentax:
I must be blind, or dumb. Either way i cannot find this setting......
Can someone explain?
11-10-2010, 01:44 AM   #13
Click the down arrow button to go to the flash menu from the main status screen. Then use the the scroll wheel thing to adjust flash brightness.
11-11-2010, 02:14 AM   #14
KxBlaze's Avatar
I'm really glad someone told me about this flash strength. I tried it today and when I don't have my diffuser with me, this is the next best thing. I was actually able to shoot someone's face at night with skin tones not too harsh while lighting up the background a little too.
11-11-2010, 11:44 AM   #15
QuoteOriginally posted by Cinders Quote
Oh my GAWD!!
This is GREAT!
I have the Puffer and at full strength it is too strong, with the puffer and slightly toned down flash this will work perfectly for Thanksgiving/Christmas photos.
camera, flash, k-x, k-x flash, pentax help, photography
Black & White Brute Strength dugrant153 Post Your Photos! 6 07-13-2010 12:05 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
How does flash strength (off-camera) work? Vormulac Flashes, Lighting, and Studio 2 01-18-2010 01:35 PM
Strength of Character II Mike Cash Post Your Photos! 0 07-06-2008 09:06 AM
Strength of Character Mike Cash Post Your Photos! 14 06-11-2008 04:15 PM
All times are GMT -7. The time now is 07:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
