11-10-2010, 10:16 PM   #1
k20d with older lenses
hi all,just picked up a second hand k20d and trying to set up the camera for use with older f-smc 70-210 lens and 35-70.,as im a newbie with this unit ,any help would be greatly appreiciated.
11-10-2010, 10:18 PM   #2
Bramela's Avatar
What exactly are the problems you are having, if any?
11-10-2010, 10:44 PM   #3
The 2 F series lenses should work without any specific setting change on your K20D. But if you received the F---- msg then check that the aperture ring on the lenses are set to 'A' position.
11-11-2010, 12:04 AM   #4
hcc
hcc's Avatar
QuoteOriginally posted by elpolodiablo Quote
+ with elpolodiablo
Do check that the aperture ring on the lenses are set to 'A' position.
11-11-2010, 01:03 AM   #5
Welcome aboard. When you make sure everything is working properly, put that 35-70 on the camera and go walking around with it. It's what I call a real sleeper. That is, a very nice lens that seems to get overlooked quite often.
camera, k20d, pentax help, photography
GEneral question about K20D and older lenses jeryst Pentax SLR Lens Discussion 6 11-25-2009 11:38 PM
K20D metering with older lenses (again) Wayno Pentax DSLR Discussion 8 06-23-2009 08:57 PM
Some Questions on Older K20D GregK8 Troubleshooting and Beginner Help 2 02-27-2009 02:36 PM
Older lenses for K20D? poyntnshuteguy Troubleshooting and Beginner Help 5 02-23-2009 09:52 PM
K20D and older flashes ljlayne Flashes, Lighting, and Studio 9 07-16-2008 12:00 AM
All times are GMT -7. The time now is 12:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
