11-17-2010, 07:00 PM   #1
Help with telephoto lens selection
I am very new to DSLR photography and need some recommendations for an automatic telephoto lens. My son is playing sports, football, basketball, and baseball, specifically. I want a lense that will allow me to be in the action. Here is my setup: K200D, Pentax Lens DA 1:3.5-5.6 18-55mm AL, Rokinon Lens 1:2.8 28mm
, Vivatar Lens 1:5.6 300mm Telephoto 58mm. Any recommendations will be very appreciated!
11-17-2010, 07:15 PM   #2
twitch's Avatar
For about $350 the DA 55-300mm f4-5.8 is an excellent option and would suit the purpose of shooting outdoor sports. I have one and it's terrific. For indoors it's pretty marginal though (and for a K200D probably not workable), I use my K-x + DA*50-135 f2.8 indoors due to it's faster aperture. Indoors even at f2.8, I'm shooting at 1600ISO and even 3200ISO at times. A K-x can do this though and still produce acceptable images.
11-17-2010, 07:36 PM   #3
ChipB's Avatar
I also have the DA 55-300 lens - great! But at f4-5.8 it's not really suited for indoor sports - unless the court is VERY well lit. I'd say you problably don't want a lens that's slower than f2.8 for the indoor stuff.
You might think about getting one of the 135mm f2.8 (or f2.5) lenses - there's a ton of 'em and fairly cheap. There's various Pentax/Takumar versions - complete with the "A" aperture setting.
The field opens up considerably if you don't need the "A" setting (pretty easy to take a test photo or 2 to get the exposure set) - there's some pretty decent Vivitar models, and surprisingly the Sears ones are, in general, pretty decent.
Check the lens review sections - Pentax and/or 3rd party - that'll give you a pretty good idea what folks on the forum think of various lenses.
Good luck.
11-17-2010, 07:45 PM   #4
KxBlaze's Avatar
I agree with the other posters. The DA 55-300 will be great for the baseball and football and can be had used for around $300 or even less for the DAL version.
But for basketball you will definitely need something faster. If you can afford it then the DA* 50-135 would be very good. The cheaper route would be some manual primes of greater then 100mm. Those are all over the place and are less than $200, some much less.
11-18-2010, 10:04 AM   #5
Lowell Goudge's Avatar
given your present camera, the K200D which uses the 10MP CCD sensor, you are limited in ISO so for indoor sports, or outdoor on a cloudy day you will be challenged by the relitively poor High ISO capability of the camera.
Not that I would suggest changing cameras here because the K200 is still a capable camera, But.....
to use your existing camera, and get good indoor shots, you should be looking at a 70-200F2.8 lens.
Ideally one that you can mate up with a 1.4x or 2x TC to use for all indoor and outdoor shots.
If you don't mind getting a used lens, look at a sigma APO 70-200 F2.8 EX but not the HSM model, a screw drive one, and the 1.4x and / or 2x teleconverter.
These lenses usually sell for about $600 used, and are excellent, I have the Non DG version, and it is reputed to be the best overall.
I use it for wild life but the same challenges exist
11-18-2010, 10:19 AM   #6
psychdoc's Avatar
Since you will need to shoot indoor for basketball get lens with f2.8,
The choices are:
pentax 50-135 f2.8 [I use this; somewhat short for outdoor for some but fits my needs; less bulky too]. Takes SUPERB pictures.
Sigma or tamron 70-200 f2.8 [longer]
11-24-2010, 01:19 PM   #7
That's exactly right. I don't shoot sports with my K200D, but I do use it to shoot wildlife (almost always on cloudy days) with a DA* 300, and even at ISO 400, if the animal is moving, forget it, there will be blur. I was shooting elk jumping over a fence last weekend, but none of them came out. Longer lenses require faster shutter speeds; and if the light is not there and you don't have a camera that will let you dial up the ISO, it can be a real challenge to photograph moving objects.
The other problem with the K200D is the mediocre autofocus. If I were shooting sports with my K200D, I would be tempted to use manual focus primes. It does take a bit of skill to manual focus on moving objects, but it's not the like the K200D's autofocus is going to do a heck of a lot better. Moreover, relatively fast (i.e., f2.8) manual focus telephoto primes can usually be found for under $200, and some of them a very good lenses.
If AF is absolutely necessary, the best one lens solution is either a Tamron or Sigma 70-200/2.8; but those lenses don't come cheap.
11-24-2010, 02:42 PM   #8
The K-x's excellent high ISO (3200-6400) may let you get by with a lens slower than F:2.8
see: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/107773-pentax-...so-6400-a.html
See: Ubuntu https://www.pentaxforums.com/forums/pentax-beginners-corner-q/120036-theatre-photography.html
See: dpreview . com review of K-x p.15.
F5.6@ISO 6400 is equivalent to F2.8@1600 (2 times f-stop is equivalent to 4 times the ISO at constant shutter speed.)
That's not to say that F:2.8 wouldn't be nice, but there's few affordable long ones out there.
Dave
11-25-2010, 08:17 AM   #9
germar's Avatar
Crop your image
While your K200D presents a challenge with its sensor, I would tell you to find a medium long lens that is as fast as your can afford and then CROP your image to finish off the tele-effect.
The 50-135 comes to mind as a really beautiful, fast lens that would allow you to crop a bit to give a feeling of a longer lens. It's speed will allow you to shoot indoors as your describe.
While not an AF lens, I might suggest getting a Takumar 135mm f2.5 lens. This is MANUAL focus, but this lens is legendary for its image quality and is a very fast lens indeed. Copies can be found in the 180-210 range. You can surely crop to give yourself the view afforded by a much longer lens.
11-25-2010, 01:06 PM   #10
QuoteOriginally posted by newarts Quote
Dave
The point of this apparently non-responsive comment was to consider buying a K-x.
If that's not practical, I agree with the others that a 2.8 lens or faster is required for the K200D.
KEH has some lenses listed that might suffice. I'd look for a 100-135mm lens; a 135mm lens, 54' (mid-court seat) from the basket will provide a portrait mode image that includes basket and floor.
Here's a link to some good screwmount lenses (I find them easy to use with an inexpensive adapter.... use catch-in-focus or the green hexagon to detect focus.)
Pentax Screwmount Fixed Focal Length Lenses - KEH.com
The Super-Tak 105:2.8 at $79 and the Super- Tak 135:2.5 at $84 are good buys. Keh's BGN grade lenses are of good optical quality.
Keh also lists some k-mount lenses of interest to you:
Pentax Manual Focus Fixed Focal Length Lenses - KEH.com
SMC 100:2.8 at $89
Takumar Bayonet 135:2.5 at $49 (has a reputation for being quite soft wide open -just where you care- and subject to flare).
Of the lenses above I'd probably go for the Super-Tak 135:2.5 screwmount because of its superior sharpness.
Dave
11-26-2010, 08:09 PM   #11
I guess a lot depends on what you are willing to pay. A 70-200 f2.8 (either Sigma or Tamron) would be a nice lens for most situations. The DA * 60-250 seems to have really amazing image quality wide open. I would hesitate to recommend the DA * 50-135 because, while its image quality is great, its auto focus is quite slow and it seems much more suited for portraiture.
I guess the other thing that I would recommend is a monopod. Others have mentioned that with longer lenses you are much more likely to get camera shake and this can really reduce that (most places won't let you take a tripod in, even if you wanted to).
I'm sure you'll get some great photos.
camera, lens, pentax help, photography, recommendations, telephoto, telephoto lens
Help with lens selection splurf Troubleshooting and Beginner Help 3 11-20-2009 08:17 AM
Slimming my lens selection Erenon Pentax SLR Lens Discussion 8 01-21-2009 01:46 PM
Help with lens selection JamesD Pentax DSLR Discussion 39 10-30-2007 04:59 PM
Lens selection Flaco Pentax SLR Lens Discussion 8 12-01-2006 06:23 PM
Need lens selection help? DJR Pentax SLR Lens Discussion 4 09-18-2006 06:58 AM
All times are GMT -7. The time now is 08:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
