11-27-2010, 07:32 PM   #1
Lens hoods?
Hi i was wondering if a tulip lens hood or just a round lens hood is better?
11-27-2010, 07:41 PM   #2
Tulips are usually better for zooms, as they're fitted for each particular lens. They're easier to put on and offer more shade, but are harder to get your hands on.
With primes, you'll oftentimes still see round hoods as the focal length is fixed and the whole thing can be as long as needed.
11-27-2010, 08:55 PM   #3
Ananta Androscoggin
Guest
I've personally discovered that bayonet-mount tulip lens hoods don't spin around as you change focus, which the screw-in-the-filter-thread tulips do. Unless you have a lens which doesn't rotate the 'business-end' of the lens barrel as you focus (I don't).
11-27-2010, 09:32 PM   #4
Hi matsui,
Tulip hoods are designed to prevent or at least decrease corner vignetting, which is more relevant to shorter FL lenses. They do probably protect a bit more against stray light, but only in some instances and certain situations.
For tele lenses, the petals probably serve no significant function other than allowing a design that is deeper yet more cylindrical than conical.
The petaled ones are cooler looking though. . .
Scott
11-28-2010, 01:14 AM   #5
I suspect it's that a lens hood for a wide angle lens has to be a tulip and for a longer lens can be round, hence a hood for a zoom that goes from wide to longer (like the 18-135) will have a tulip hood that won't be so effective at the long end - an optimal hood for the long end would cause problems at the short end.
11-28-2010, 04:44 AM   #6
Manel Brand's Avatar
QuoteOriginally posted by matsui255 Quote
Just to add that tulip hoods are more effective than the more conventional cylindrical because they are designed to mimic the best shape for the sensor/film plane which is the rectangular; a tulip (or petal) shape is, in simple terms, a projection of a rectangle on a spherical space; if you look at a professional movie/video camera generally you will not see a circular hood but rather a rectangular. On a photographic camera they look kind of awkward but they were and still are used in some old cameras.
11-28-2010, 10:32 AM   #7
fotaki's Avatar
QuoteOriginally posted by cats_five Quote
Not in every case. I have a tamron SP 60-300mm for which I use a 3-stage round rubber hood. I use the same on a few other of my manual zooms to good effect. In the case of the 60-300, the third party hood is far more effective and easier to use than the original (covering as it does all FL's).
Some 'petal' hoods I've seen rotate and have a locking screw - so one can use them on rotating lens barrels. Not really sure that's much advantage in the end.
11-28-2010, 11:37 AM   #8
So do you think I should even buy the hood I am kind of confused. I have the Pentax 18-55 and 55-300.
11-28-2010, 11:48 AM   #9
QuoteOriginally posted by fotaki Quote
Right. No practical use, IMO.
11-28-2010, 11:50 AM   #10
What happened to the standard hood of the lens? Didn't come with one?
11-28-2010, 12:01 PM   #11
TaoMaas's Avatar
You should invest in a hood of some kind for your lenses. If you don't have the factory hoods, pick up an after-market hood. After-market hoods may not have been designed specifically for your lens, but even a modest amount of protection is better than none at all.
11-28-2010, 01:08 PM   #12
Jodokast96's Avatar
Amazon.com: Fotodiox Lens Hood for Pentax Ph-Rba SMC DA 18-55mm f/3.5-5.6 AL II Zoom Lens as 38741: Camera & Photo for the kit lens anyway.
11-28-2010, 01:21 PM   #13
fotaki's Avatar
In theory the 'petal' hood with locking screw can be used with a PL filter viz. to adjust the filter and hood to give normal cover. However, in practice.......?
IMO it's not absolutely necessary to use the original hood. If your lens comes without it, there are plenty of third party alternatives that work effectively.
As already said above, all lenses will benefit from the use of an appropriate hood.
11-28-2010, 05:58 PM   #14
QuoteOriginally posted by Manel Brand Quote
No the new ones do not come with them anymore I guess.
11-29-2010, 02:09 AM   #15
That's a shame but you can buy them cheap and you should do so. A lens hood is an important accessory to photography for reasons already mentioned.
Jodokast has already pointed out a cheap lens hood replacement for your lenses, so no big deal, buy one and your problem is solved.
camera, hood, lens, pentax help, photography
Do I need 2 lens hoods? lovemehate Pentax SLR Lens Discussion 24 10-16-2010 10:06 AM
lens hoods beer_nuts Pentax Camera and Field Accessories 4 06-21-2010 09:33 AM
Lens Hoods? MrApollinax Pentax Camera and Field Accessories 3 01-25-2009 07:57 PM
lens hoods, lens caps, UV filters and camera storage Ed in GA Pentax SLR Lens Discussion 4 12-22-2007 01:40 PM
Lens hoods Trawlerman Pentax Camera and Field Accessories 1 09-11-2007 07:24 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
