Originally posted by VelvetFoot Does it pay for a beginner to shoot in RAW format? Will there be regrets at some time in future when I want to do some post processing? High quality jpegs can be processed some as well, no? I have no fancy processing software and am thinking of just shooting at the high resolution jpeg for the immediate future.
Am I doing good/bad, etc?
Thanks.
As Adam points out, you can still do some modification in post-processing of jpegs. And RAW files are, indeed, more difficult to manage. They're also much larger, so they take up a lot more space on disk.
However, I don't think that you would have any regrets in the future, if you shot RAW now. The reverse might be true. Its possible that, by shooting exclusively in jpeg, you might capture an image that is marginal and makes a lousy jpeg, but could be saved in RAW. If you had it in RAW, you could come back to it in the future, when you are more comfortable in RAW, and process it then, perhaps saving an image that might otherwise be lost.
One solution is to shoot both simultaneously. Set the capture mode to RAW+JPEG. This is what I do. In many of my shots, the jpegs are fine. In some, however, I'm glad I have the RAW file to start from.
One example of a trick that I read of in a book on RAW shooting, by a professional photographer. In very low light, when you don't have or can't use a tripod, you may find that the shutter speed must be so slow that even the camera's SR can't save it. In a case like that, if I don't want to use flash, which I often don't, I deliberately underexpose the shot by two or three stops. This allows me to raise the shutter speed to the point where it can be safely handheld. Then, in post-processing, using the RAW file, I can almost always recover those two stops of exposure. With a jpeg, too much sensor information is lost to allow that.
The only drawback to shooting RAW+JPEG is the space it takes in your memory card and on your computer's hard disk. Both are relatively cheap, so, to me, that isn't a deal-breaker. For example, with my K10D, and a 2GB SD card, I can get around 680 high-res jpegs on the card, but only 128 shots in RAW+JPEG. I seldom shoot that many shots in a session, and, if I do, I have several SD and SDHC cards, so this isn't an issue. On my camera, three star (highest) jpegs are about 3MB, and RAW files are about 13MB. Newer cameras, with higher resolution sensors and four star jpegs, will produce larger files.
All that being said, there's nothig wrong with shooting just jpegs. Lots of photographers, even experienced ones, do so. Some people simply don't like editting on the computer.
