12-05-2010, 04:36 PM   #1
optical slave flash help
Hi,
I am trying to "fill flash" with an on camera flash and an off camera optically triggered slave flash (K10d and a Phoenix D91-BZS). The flash is capable of sensing the pre flash and waiting for the main flash. I have tested this and believe that it is correct.
The problem I am having is that when the camera triggers the off camera flash ( I see it pop), the picture (down a long hallway) is darker than when I just use the on camera flash by itself. It appears that the off camera flash fools the camera's PTTL sensing system and gets it to turn off too early.
Any thoughts would be appreciated.
Kev
12-05-2010, 06:21 PM   #2
Just1MoreDave's Avatar
The P-TTL system is supposed to fire a pre-flash for metering, figure out a power setting for the flash controlled by the camera, then take the photo with that setting. So your off-camera slave flash would only alter the P-TTL exposure if it fired during the pre-flash.
What I don't know about flash could fill a book, so that's as far as I'll go for now.
12-05-2010, 06:46 PM   #3
jimH's Avatar
Almost sounds like your off camera flash is actually triggering on the pre-flash and not recharging for the actual flash and leaving your photo under exposed.
12-06-2010, 12:43 PM   #4
Thanks for Just1moredave and jimH. I tried it again and found and fixed 2 problems. I set the flash up in detect mode, previously I set it in 2 flashes mode, and I also found that the flash has a difficult time in brighter light.
I went inside for a couple of test shots and it works.
03-26-2011, 11:07 AM   #5
Eso mismo me pasa a mi... como que disparara un preflash inicial.. y luego ya no dispara el flash principal y las fotos salen oscuras.....
camera, flash, pentax help, photography, slave, slave flash
Can I run the Pentax AF-540 Flash in wireless optical slave mode ? Enc0der Flashes, Lighting, and Studio 4 12-12-2009 06:54 AM
K200D: using built-in flash to trigger optical slave? cheekygeek Pentax DSLR Discussion 5 07-01-2009 09:13 PM
For Sale - Sold: Flash + optical slave kibipod Sold Items 4 04-06-2009 05:33 AM
K10D - has anyone found a way to trigger optical slave with onboard flash? Hornet Pentax DSLR Discussion 19 12-01-2008 03:27 PM
af360 and k110d optical slave ronald_durst Flashes, Lighting, and Studio 3 05-09-2008 01:55 PM
All times are GMT -7. The time now is 07:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
