Originally posted by gcoello Wanted to get some opinions on a configuration for lens reversal...not wanting to spend any money, other than for the adapter ring. Just want to have some fun with an area of photography that I never thought I'd be interested in.
Here is what I have...I'd like to get some thoughts about what lens should be on the camera body, and what lens I should reverse.
Camera
K20D
Autofocus
Pentax 18-55 3.5-5.6 kit lens
Sigma 28-80 3.5-5.6 Macro
Manual Focus
Pentax-M 50mm 1.7
Sigma 70-210 4-5.6 UCII
I also have an off-brand magnifier that I can screw onto the front of a lens. Although I couldn't secure it, I was able to slide the magnifier over top of the outside of the M50 for a snug enough fit that I could focus. Would it be better to just get a step up adapter instead?
Looking forward to your replies...
I would think you should try the 18-55 on the body with the 50 kissing it. It may not matter much what you set the aperture of the 50 to but you may as well use it open to send in as much light as you can. With the 18-55 on the body, at least your light metering will be much easier and can be controlled via the camera body.
You are not going to use any automatic focus with the lens or body so forget about that in the equation.
