Originally posted by DaveHolmes If you're using the two kit lenses and when you turn the mode dial from Av to M and the BIG M appears in the LCD and you press the AV button (marked +/- ) and it doesn't toggle between shutterspeed and aperture... Then your AV button (marked +/- ) is broken... You need to send that badboy back...
Oh, that's exactly what's going on...i was afraid of that just wanted to make sure i tried everything possible rather than assuming it was broken since i'm new to this type of camera and all.
Well I'd like to thank all of you for your time and help!
