11-15-2014, 11:49 AM   #16
Otis Memorial Pentaxian
I believe he is referring to a small pin on later SMC tak's which was part of the modification to provide open aperture metering on the ES II and spotmatic F bodies
I also thought that might be his intent, except that the small pin is completely covered by and depressed by the adapter and is also completely inside the K-mount opening.
11-15-2014, 12:09 PM   #17
Na Horuk's Avatar
If you mount the adapter on the camera, the pin can bump into the af screw drive as you turn and screw the lens. Only if the pin is not limp and inside the lens and af is selected on camera. At least on my flektogon with K-01
11-15-2014, 01:00 PM   #18
PM me a photo of your Flektogon mount with the adapter fitted. I suspect we have a confusion of terms here. I am only aware of two cases of couplers on the M42 mount face. On is the small pin on SMC Takumars (depressed by the adapter) and the other is the protruding pin on Mamiya/Sekor SX lenses that makes mounting impossible. It may be that CZJ might have some creative variations of the M42 standard I am unfamiliar with. The only issues I have had with M42 and the AF drive is for those lenses where the mount face has wells for mounting screws in the path of the drive pawl. Depending on thread entry point the hole can "descend" onto the pawl resulting in a potential jam. This is another good reason to mount adapter to lens before attaching both to the camera. On second thought I would suggest always depressing the lens release button when mounting/removing M42 lenses. Doing so retracts the AF drive so that all is out of harms way.
11-15-2014, 02:11 PM   #19
jatrax's Avatar
Might be a new record for old thread revivals........... 12-23-2010 --> 11-15-2014
11-15-2014, 02:43 PM   #20
p38arover's Avatar
On the type (3) lenses I bought a couple years ago, I superglued the auto-pins, but I find I can't un-glue them. I now avoid buying such lenses, just as I avoid lenses with apertures stuck wide open.
I know this is very late but you might try brushing on acetone or nail polish remover in the hope it can track in and dissolve the superglue.
11-15-2014, 02:57 PM - 1 Like   #21
boriscleto's Avatar
QuoteOriginally posted by p38arover Quote
Extremely late as RioRico said goodbye to the forums in September of last year.
camera, pentax help, photography, switch
Switch lenses often or let some shots go by? PocketPixels Troubleshooting and Beginner Help 18 01-01-2010 08:26 AM
Why do some DA lenses have Autofocus switch? Andi Lo Pentax SLR Lens Discussion 11 03-09-2009 07:01 PM
For Sale - Sold: M42 / K / KA / FA Lenses Grab bag of Vintage to Current lenses. 50mm FA f/1.4 MikeDubU Sold Items 10 02-09-2009 12:45 PM
Question About Auto/Manual Switch on Vivitar M42 Lens zx-m Pentax SLR Lens Discussion 2 06-11-2008 06:49 PM
For Sale - Sold: SF1 Kit, ME w/50, 250/SL, K AF Lenses, M42 Lenses 247nino Sold Items 5 05-07-2008 04:28 PM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
