Originally posted by cardinal43 Might be a dumb question, but does this mean you slide the switch to cover the man, leaving the auto visible, or is it the other way?
No dumb questions, just dumb answers. Duh.
Anyway, the setting you want should be VISIBLE. So to switch to M(an), slide the switch so A(uto) is covered and M(an) is displayed. You can verify that you've done this right by setting the aperture to f/8 or thereabouts. With A(uto), the iris will stay wide open. With M(an), the iris shuts to f/8. Also, in M(an), the diaphragm linkage pin won't slide in. Cheers!
