12-19-2010, 10:50 AM   #1
Any advice on snow shots with K7
Yesterday I did some shots on a hill and had difficulties to find correct settings.
Seems like everything comes underexposed on snow even with the EC +1.
Here is my results:
Exposure 0.002 sec (1/640) Aperture f/5.8 Focal Length 300.0 mm ISO Speed 200 Exposure Bias +1 EV
12-19-2010, 11:04 AM   #2
mysticcowboy's Avatar
In bright snow about 2 EV usually works. With overcast 1-1.5 is good. The problem is that exposure meters want to make the snow a middle gray.
12-19-2010, 11:38 AM   #3
In snow conditions I usually run Manual that way I'm not relying on the camera's metering. Like mysticcowboy said, the camera views snow as gray so you just have to compensate...
12-19-2010, 01:27 PM   #4
Get the feel of the exposure - take a shot with (say) +1.5EV compensation and check the histogram. Repeat if necessary, but remember slightly underexposed is better than slightly overexposed.
12-19-2010, 02:02 PM   #5
Ash
Community Manager
Ash's Avatar
These results are quite expected.
And as you're using a lens that normally requires some +ve EC, then in snow this underexposure will be even more accentuated. Keep pushing up the EV to taste.
12-19-2010, 02:10 PM   #6
GoldenRGuy's Avatar
QuoteOriginally posted by mysticcowboy Quote
So press the +/- button and turn the rear wheel? Press the green button to reset?
12-19-2010, 08:55 PM   #7
SpecialK's Avatar
Exactly. Some knowledge of the "zone system" will help estimate what EC is needed.
Zone System - Wikipedia, the free encyclopedia
12-20-2010, 07:34 AM   #8
You can also "spot meter" on the subject, and use the "exposure lock" button to keep the proper exposure setting while you recompose and shoot.
12-20-2010, 08:27 AM   #9
the "M and green button" trick
QuoteOriginally posted by flyer Quote
Yes, that'll work for one shot. You'll need to repeat it for every shot though. Even better, put the camera in M, spot meter the subject and press the green button. That will set the M exposure reasonably.
Providing the subject is middle-toned of course. Apply correction as needed.
You can also spot meter the snow and add 2 stops.
Regards,
--Anders.
12-20-2010, 09:05 AM   #10
If it's a sunny day with not much cloud cover, meter off the blue sky.
12-21-2010, 06:02 AM   #11
Thanks to everyone!
I will try to use fixed manual settings for the static shots, but when I follow the subject, I will bump AE and use the Tv mode.
What about the White Balance? I had to reset it during PP. The snow was blue with automatic WB settings.
12-21-2010, 08:43 AM   #12
QuoteOriginally posted by vladm11 Quote
Suggest using a preset (daylight or cloudy, depending on the conditions) or best results will be setting a custom WB off of a grey card, or any known white (shirt, toque, perhaps clean snow).
12-21-2010, 08:50 AM   #13
Depends how blue. Snow often does have a blue tinge especially in shadows. But if it was all pretty blue then the WB was wrong.
12-21-2010, 10:30 AM   #14
GoldenRGuy's Avatar
I got blue snow changing the WB to Tungsten. (on purpose 'cause it looked cool!)
12-23-2010, 04:10 PM   #15
Canada_Rockies's Avatar
When I take snowy images, I meter the snow in Manual exposure and add two stops. That means metering with only snow in the picture in the same lighting as the subject. I leave the camera in manual exposure at those settings. As Pentax cameras (not sure about the K-5) generally give 1/3 - 1/2 stop of supposed under exposure*, I find two stops works just fine. Another way to work this is to use a substitute metering subject that works out to 18% grey and use no exposure compensation - but still using manual exposure mode.
*the supposed underexposure actually retains the highlights. Pentax metering up to and including my K10 blows out the highlights almost never. It was adjusted so that slide film such as Fuji 50 or Kodachrome 10 or 25 would have perfectly exposed slides.
bias, camera, ev, exposure, iso, length, mm, pentax help, photography
Misc A few shots from the garden covered in snow chaude Post Your Photos! 2 12-19-2010 12:31 PM
Want to try my K7 in the snow...Advice seachunk2 Troubleshooting and Beginner Help 15 02-13-2010 09:48 AM
People First Snow Shots kewpie-o Photo Critique 7 02-07-2010 06:32 PM
Nature Snow Shots dadipentak Post Your Photos! 3 01-09-2010 02:51 PM
Two Snow Shots kpfeifle Post Your Photos! 4 03-19-2007 01:35 PM
All times are GMT -7. The time now is 12:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
