Originally posted by LIGirl Actually, I did know that different light casts different colors...here's my follow up question. The bulbs in the house I'm taking pictures in right now are those energy efficient type. Do they create a different color cast then a regular light bulb? That would at least explain why tungsten doesn't seem to do the trick
OK, I apologize for making assumptions.
The energy-efficient bulbs are all over the map. I have ones in my house that are like incandescent at 2800K, but also 3000K, 3500K and even 6500K. (A chart in your manual decodes these numbers if you aren't familiar with the scale.) Add regular fluorescents at 4100K and some LEDs that are really weird. The different brands might also produce broad or narrow ranges of colors, depending on the chemicals used to coat the insides of the tubes. I can easily get a portrait of someone who's blue on one side and yellow on the other, if they're in the wrong place. The compact fluorescents often are marked with a color temperature, or have it on the packaging.
Setting the white balance with a piece of paper works pretty well. You can free yourself from some WB problems by shooting RAW, which allows you to apply a white balance afterwards. But it won't help if a person is lit by two different color temperatures.
