12-28-2010, 02:43 PM   #1
ist DL Problem
My ist DL will not switch out of AV mode. Does not matter where I put the selector switch. Does not matter if I have it to auto mode. still stays in AV mode. Any suggestions besides sending it in for repair. I have about 10,000 shots on it.
Thanks
SamIV
12-29-2010, 12:03 AM   #2
QuoteOriginally posted by SamIV Quote
Thanks
SamIV
Ask a moderator to move this to the DSLR section. This isn't the place for it. You'll get better answers there anyway (but sending it in or replacing it is probably the solution).
12-29-2010, 02:13 AM   #3
Moved to the technical troubleshooting section.
12-29-2010, 08:37 AM   #4
Hi Sam,
The first thing to try is to reset all your camera settings via the Reset menu choice.
The next is to swap out the batteries. Low charge can do some strange things.
The third thing I'd try is to leave the batteries out for a day, then try it again.
If none of these work, I'd call Pentax support and see if this is a problem that they have dealt with in the past with this model. The last resort is sending it in for an estimate of repair.
-- There is one other alternative-- shoot in Av priority. My cameras spend 99% of their time in this mode, and there are all kinds of ways to get the settings that you want for just about any situation.
Scott
01-01-2011, 10:57 AM   #5
DL Parts list
The selector switch may be bad. If you want to try to fix it yourself, here is a parts diagram.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/48910-pentax-ist-d...oded-view.html
01-01-2011, 11:29 AM   #6
QuoteOriginally posted by gp1806 Quote
This may be a useless reply but are you sure you have a ka lens on the camera. I know that if I place a k kmount lens that is not a ka mount the body will only go av mode other than m mode. But if all your lenses are doing the same thing then it is not this unless your contacts are messed up. Just a thought you could take a look at.
av, dl, matter, mode, pentax help, switch
problem with my *ist DL Ne0n730 Pentax DSLR Discussion 2 02-24-2010 10:48 PM
ist-DL problem chromo Pentax DSLR Discussion 18 02-18-2010 03:25 PM
Problem with ist DS bigberg50 Pentax DSLR Discussion 3 10-27-2008 01:10 PM
IST-D overexposure problem stwinkc Pentax DSLR Discussion 4 03-10-2008 03:24 PM
*ist D power off problem outsidenote Pentax DSLR Discussion 4 02-07-2008 06:30 PM
All times are GMT -7. The time now is 12:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
