Originally posted by RioRico Do not concern yourself with crap factors. Such are ONLY meaningful if you are an experienced 35mm photographer transitioning to a modern dSLR. Otherwise, only confusion awaits you. Put it out of your mind. Just learn what the world looks like when looking through any specific lens.
What you'll learn is: A lens whose focal length (FL) is about the diagonal its the camera frame (film or digital sensor) is 'normal'. On APS-C cameras like your good Kx, that is about 30mm. Anything with a FL that is 2/3 'normal' or shorter is WIDE. Anything with a FL that is 5/3 'normal' or longer is LONG -- long enough for portraits, anyway. As mentioned, an 18-250 superzoom goes from WIDE to VERY LONG -- and is my most-used lens.
this is about right, just take an all purpose lens (18-250 ect...) sit in a space that you know, start playing with it and then you'll know what focal length you need...
The only reason why you would bother with crop factor is if you had the 35mm system before, and you already know the focal length, and you want to apply it toward the APS-C crop field.
It's quite simple. 35>>> APS-C you have a 1.5 crop factor (times it by 1.5, so 50mm = 75mm).
The micro 4/3 is a 2X crop factor (50>>> 100)
the canons are actually 1.6 but you can do 1.5 since it's not much difference.
Alot of time people will tell you "it's not wide enough ect...", the only thing that you need to worry on APS-C is wide angle, due to the crop factors it's very hard to get wide... in the old days 20-24 is wide, but with APS-C 18 = 27... and it's very hard to even get lens at 18mm.
