12-30-2010, 10:39 AM   #1
digital noise
I use the K100D and im wondering my it seems I get so much noise? I use auto quite a bit since im starting out and it just seems that some have none and some have Alot ! why?
12-30-2010, 10:54 AM   #2
Shots taken with higher ISO (800, 1600) will have more noise than shots taken at 100, 200, or 400.
If you have ISO set to 'Auto', the camera is choosing and may select a higher value than you'd prefer. I'm not sure how the menu is set up on the K100D, but on my K200D you can set ISO to 'Auto' and then set a range using the control wheel.
12-30-2010, 11:07 AM   #3
KxBlaze's Avatar
It's definitely the Auto ISO. My suggestion would be to read up on Aperture, Shutter Speed, and ISO and try to shoot in Manual mode. That's what I did and it helped me learn a lot.
12-30-2010, 11:45 AM   #4
Just1MoreDave's Avatar
The ISO setting can increase noise in-camera. Some software creates noise on its own by automatically increasing brightness or exposure levels. Sharpening can make noise show up too. Noise is more visible in shadow areas, where you expect black and get a rainbow of colors. With a more evenly lit subject, you'll see less noise.
camera, im, noise, pentax help, photography
SR noise in K-x Hemi345 Video and Pentax HDSLRs 3 02-17-2011 09:17 PM
Another.....K-7 noise..... the swede Pentax DSLR Discussion 11 10-17-2009 02:57 AM
Digital Filters in Pentax Digital Camera Utility 4? lawsonstone Digital Processing, Software, and Printing 0 07-19-2009 04:44 PM
cs3 noise filter vs. noise ninja vs. ??? reknelb Pentax DSLR Discussion 0 03-04-2008 04:55 PM
All times are GMT -7. The time now is 10:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
