12-30-2010, 12:55 PM   #1
K-x e-dial!
Hmm..so my K-x's e-dial seems to be giving me the jitters. Whenever I turn the dial towards the right, which should stop down the aperture or fasten the shutter speed etc., it does random things i.e it decreases, then increases, then increases, then decreases, then increases...you get the idea. Same thing vice-versa too. Also, I have to, like, turn the dial 10 times to either side to stop down one aperture of increase/decrease the shutter speed by one stop.
Anyone's got any solutions, I am all ears.
12-30-2010, 04:34 PM   #2
Ira
What mode are you shooting in?
12-30-2010, 10:59 PM   #3
i mainly shoot in Av. But this problem persists in any mode I choose
12-31-2010, 08:06 AM   #4
Ira
This doesn't sound good.
01-01-2011, 01:49 PM   #5
ovim's Avatar
My K-r developed the same fault after about a month of use. I got it repaired under warranty and apparently a circuit board was changed (at least that's what I was told).
01-01-2011, 05:05 PM   #6
KxBlaze's Avatar
Definitely a warranty issue (if it is still covered) or a professional repair issue. Like Ovim your camera probably needs an electrical fix, something I would not feel comfortable doing myself.
01-02-2011, 06:19 PM   #7
ChipB's Avatar
Or, if the camera is no longer under warranty, you could try using an electrical contact cleaner. Get the good stuff that doesn't leave any residue. Here in the States its availabe from stores like Radio Shack or electrical supply places. Spray it into the e-dial area from the bottom (camera upside down) then work the dial rapidly back and forth. Oh, yeah, remove the battery before doing this.
Good luck!
01-02-2011, 07:44 PM   #8
amidtb994,
I have a very similar issue on a istds.
It works properly however, if the EV error is within plus or minus 3.0 (in the viewfinder, on the far right). So problem does not often occur. I wonder if its a firmware issue, not a mechanical switch problem.
If the wheel is clicked to the left so that the exposure error increases to more than 3.0 and starts to flash, then it gets the jitters. Problem is worse if spot metering is selected
The problem clears in M mode when the manual exposure button is again pressed to bring the exposure error back to 0.0.
01-09-2011, 10:38 PM   #9
I wouldn't use the contact cleaner currently available at Radio Shack. Such cleaners used to have a chlorofluorocarbon formulation that is now not legal. Current contact cleaner may damage plastic. The only safe cleaner would be Asahiklin 225 available from Micro-tools.com. It is not cheap and probably won't solve the problem, but at least it won't mess up the surface of the body.
01-09-2011, 10:57 PM   #10
Forget about Radio Shak. That place has sucked for years. Get some of this.
Blue Shower Contact Cleaner
if you're going to spray contact cleaner in your camera. Personally I wouldn't do it though, I would just have it fixed.
01-10-2011, 02:18 PM   #11
jhaji's Avatar
I have the same problem with my *ist DS. I read somewhere that you can use an electrical contact cleaner (blower type without liquid propellants) to remove the dust that causes the problem.
04-19-2011, 09:11 AM   #12
Quick Update: I dont have those contact cleaners, but I tried a lens cleaner solutions that one gets cheaply, sprayed on the e-dail and turned it round, wiped it dry.
Eureka! It worked. E-dial going fine now!
aperture, decreases, increases, pentax help, shutter
K-7 exposure dial not going down? Help please netuser Troubleshooting and Beginner Help 8 07-26-2010 11:20 AM
Sun Dial tpeace Monthly Photo Contests 2 01-10-2010 05:01 AM
What is your e-dial default? jjay Troubleshooting and Beginner Help 7 03-11-2009 10:37 PM
GBH just a few-dial up warning borno Post Your Photos! 8 06-11-2008 03:12 AM
K10D Aperature Dial jnorth Pentax DSLR Discussion 3 02-15-2008 07:45 PM
All times are GMT -7. The time now is 07:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
