Was out today, took some shots with the camera on a tripod using the remote with 3s delay. Liked one, but when I look at it properly the low bushes on the right of the island are far from sharp - in fact they almost look like there are two of everything in the original. The rest is fine and sharpened up well.
The original is a PEF, I used ACR & CS4, the psd is 15 bits, the last two steps were resizing to 1024 pixels wide and then converting to an 8-bit image so I could save a JPG to upload to Flickr.
This has me foxed. Camera shake should have affected the whole image. I have stuff in front and behind the blurry area in focus (I cropped the bottom of the image and there is stuff there that's clearly OK). It wasn't windy, plus there are no leaves on the bush and at this time of year it's all last year's growth that has hardened.
Lens issue? Camera issue? Sensor issue? Shutter blur? Anything other ideas? And what should I do to narrow down what the problem is with a view to fixing it? I might end up wishing I had stuck with my E510.
