Originally posted by FHPhotographer Interesting issue. I sent my K-x back because the VF data line was so dim it couldn't be read in sunlight. I assumed it was a design flaw, but now I'm no wondering if it was on the way to failing? If so, I wish now I had gotten a replacement instead of a refund because the K-x is, as dpreview said, "...a little cracker." I wasn't overwhelmed by the 18-55 AL, however, so I'm thinking of getting another K-x plus the DA-40 for a top notch economical street machine,
Brian
Although the K-x and DA 40mm would be a total killer kit, I also suggest you look into the 16-45mm option. This lens is very well regarded, and is cheaper than the DA 40. At constant f4, it's fast enough for most situation and offer you a very good wide angle solution as well. It's not that much bigger than the kit lens also. Just saying!
