12-31-2010, 12:31 PM   #1
datestamp
is there a way to turn on datestamping on the photo image in the k-x?
(for the photos to have the date in the lower corner).
thanks
12-31-2010, 12:46 PM   #2
hcc
hcc's Avatar
I doubt that you can turn on datestamp in the camera.
But .... with your K-x (and any dSLR), each shot is recorded with some detailed informations called EXIF data, including the date and time of the photo. These info scan be read when you review the shot and when you post-process the photo in your computer. (You can also use a freeware like www.photome.de to read these EXIF infos.)
A number of softwares will allow you to print the date on the photo. For example, Pentax Digital Camers Utility (PDCU) that comes with your K-x does. With PDCU you can choose the format, and the amount of info that is printed on the photo, as well as the position.
Hope that the info will help... and happy new year.
12-31-2010, 08:37 PM   #3
[langtitle=fr]tres interessant[/langtitle]
@hcc
Vous etes sur que avec Pentax Digital Utilities 4.30 ou version 4.31 on peut imprimer la date etc...sur les photos.
J'ai un peu cherche, et EXEPTE dans la "visionneuse" je n'ai pas trouve l'option pour la sauvegarde ou l'impression Jpeg avec cette fonction (Date Etc...)
Si vous pouviez nous en dire un peu plus.
ou avez vous trouve cette option dans PDU 4.30 ou 4.31
Merci d'avance
Bien cordialement
12-31-2010, 11:01 PM   #4
hcc
hcc's Avatar
QuoteOriginally posted by jpette Quote
@hcc
Merci d'avance
Bien cordialement
In PDCU 4.31, select File/Print the photo. The window opens and allow you to include the date stamp, change its format and its location.
Choisir Fichier/Imprimer, puis selectionner la position et style de la date.
I tried it and it works when you print the photo.
The RAW/JPEG files contain the EXIF data with the date and time. It is part of the file properties (ie EXIF data).
Hope that the comment will help...
01-01-2011, 12:31 PM   #5
@Hcc
Merci BEAUCOUP pour cette astuce, je le na connaissait pas.
Bien cordialement, et bonne annee
01-01-2011, 01:27 PM   #6
Ira
I will never understand the reason for date stamping, especially since it's in the EXIF, as well as the date of the file in your computer window.
But everyone has different needs and wants regarding this.
01-02-2011, 06:13 AM   #7
You take a photo, give a friend a print and they forget when it was taken...
pentax help
Datestamp on Pentax K10D blegs38552 Pentax DSLR Discussion 8 03-22-2009 09:54 AM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
