01-06-2011, 12:26 PM   #1
k5 pop-up flash hook (that holds the flash down) broken...
It had to happen ...
While taking my camera out of the bag this morning, I accidentally open the pop-up flash and broke the small "hook" that hold it down.
So the flash is always up.
Is it "safe" to tape it down for a couple of days before I can go to the shop and have it repaired (and/or replaced because of sensor stain) (this week-end or if possible in 2, 3 weeks because I have things to shoot with high iso and no flash)?
I'm shooting in Av/TaV and M. I don't think the flash automatically pops up in those mode; so I assume I should be ok.
Thanks.
Max.
01-06-2011, 01:07 PM   #2
Ira
How could taping it down hurt anything?
01-06-2011, 05:47 PM   #3
I don't know, maybe wear down the mechanism ? trigger the flash when popup flash is down ?
01-06-2011, 08:22 PM   #4
Ira
QuoteOriginally posted by Thesorus Quote
See if the camera allows you to go faster than 1/180th in Tv mode after it's taped down. If you can, the flash won't fire.
01-06-2011, 08:34 PM   #5
I doubt you're going to hurt anything holding the flash down. Instead of tape however, I would use a rubber band. Loop an end of rubber band under the viewfinder, give it a single twist so the rubber band is in a figure 8 shape and loop the other end over the front of the flash. Then when you want to use the flash, remove the rubber band. I'm assuming you're just looking for something to get you through the week here.
flash, pentax help, pop-up
Help! KX Pop-up Flash TAP Pentax DSLR Discussion 2 05-26-2010 01:06 PM
K7 pop up flash @#%! ordinaryimages Pentax DSLR Discussion 12 04-05-2010 02:55 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
Bouncing Pop-Up Flash... R.ticle One Photographic Technique 5 03-03-2008 06:42 AM
Pop-up flash diffuser? lapeen Flashes, Lighting, and Studio 1 09-19-2007 01:46 PM
All times are GMT -7. The time now is 08:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
