Trish
The Casino can be cruel sometimes....best to just have a meal and a drinks...:}
as far as lenses go...Ive not owned a DA*50-135..or a DA*16-50 ..but from all reports they are stellar lenses, with the 50-135 being the pick of the two...
again I do think you will have to answer what Focal length is important to you , no one can do that for you...
.as an example..I owned the 16-45 Pentax...I really thought what he hell do I need 16mm for !, but after having the lens for a month or two..I found that I really cant do without the wide end. so my new lens had to have at least 17mm...and once you want F2.8. the zooms are all in the 17-50/16-50 mm range
to get a greater FL. and still retain 17mm, you will have to go to a F4 lens..
heres two example shots with the Sigma 17-50 F2.8 OS after some PP { post process } work
so after all that...17-50mm is great for tight spaces as it has great field of View {FOV}...but you do have to get in tight for a head and shoulders ,
