01-08-2011, 05:28 PM   #16
QuoteOriginally posted by Student Quote
But the room was so bright I could have worn sunglasses, yet the picture was dark like a cave, you couldn't distinguish anything!
You would be surprised how dark it is indoors.
Seriously.
The ability of the human brain to compensate for what the eye sees is truly astonishing.
01-08-2011, 05:32 PM   #17
Well, I think I found the problem, the shutter speed was set at max! The problem I have with using low shutter speeds is that I have a condition which makes me tremble a lot.
01-08-2011, 05:36 PM   #18
Help us help you! Post the image! Tell us what the shutter speed and aperture were!
We want to help but you won't let us!!!
01-08-2011, 05:46 PM   #19
DaveHolmes's Avatar
QuoteOriginally posted by Mike Cash Quote
Also.....you still haven't mentioned what the aperture and shutter speed were. It is entirely possible that you could have taken a photo at ISO100 in that room but it all depends on what the other two exposure factors were.
There is effectively a "Holy Trinity" of correct exposure.... Each are necessary and no one is more or less important than the others
1) ISO - The sensitivity of your sensor... Bright and sunny... ISO 100... Low Light indoors... ISO 400+ etc... HOW SENSITIVE TO LIGHT DO I NEED TO BE
2) Aperture - kinda like an eye... Wide open (f3.5 on the kit lens) allows lots of light to reach the sensor... Stopped down (say f8 or f11) allows less light to enter, onto sensor... NB. smaller Aperture (higher f-numbers) generally create sharper images...
HOW MUCH LIGHT DO I ALLOW TO THE SENSOR
3) Shutter Speed - The shutter has 2 parts to its function... One part opens... allowing light to passed through the Aperture to hit the sensor... The 2nd part closes... blocking light passed through the aperture from hitting the sensor.
FOR HOW LONG DO I ALLOW LIGHT TO TOUCH THE SENSOR
Use the meter to tell when a shot is correctly exposed.... for a speed that you can deal with handheld... Hope this helps
01-08-2011, 05:53 PM   #20
DaveHolmes's Avatar
If this is the case... When shooting indoors and in lowlight... Bump up your ISO to get correct exposure with faster shetter speeds... 1/250 of a second to 1/500 should be adequate to combat shakes (depending on severity) but a good place to start...
Try using Tv , use auto ISO for now and find at what point your trembles effect ability and check exif later...
01-08-2011, 06:24 PM   #21
Okay first not too dark shot taken with my K-7 indoors. I had all lights on and even a construction projector on! It was so bright I had to wear sunglasses.
1/15 Exposure
ISO 100
Please feel free to tell me if you like my watch!
Watch | Flickr - Photo Sharing!
I dare not increase the ISO because of the noise but I opened up the aperture.
01-08-2011, 06:40 PM   #22
Mike Cash's Avatar
You needn't be concerned about the noise from ISO. Any degradation due to noise would be more than made up for by the improvement in less blur from shaky hands. Going up to ISO400 would have made that 1/15 into 1/60, which would help a lot. Nobody ever died from the noise at ISO400.
Do you copyright all your photos to George W. Bush?
01-08-2011, 06:43 PM   #23
Well since I took a picture of a Rolex I didn't want to put my real name. So I put whatever came to mind. I almost wrote Fred Astaire! What do you think of the picture?
01-08-2011, 07:23 PM   #24
1/15 Exposure
ISO 100
If you are so concerned about noise that you don't want to go above iso 100, then for goodness sakes you should be using a tripod for something that moves as fast as a watch. The drop in quality from shakiness (especially since you say you tremble a lot) going from 1/60s to 1/15s will probably outweigh the noise you'd gain going from iso100 to iso 400.
The anti shake mechanism is great, but no substitute for a solid tripod at settings like you used.
01-08-2011, 07:54 PM   #25
I still need to get used to digital...
Like other folks have already mentioned, exposure works the same as it did with film. The physical properties of light/optics have not changed.
01-08-2011, 07:56 PM   #26
Okay, I chose ISO 100, adjusted focus but did not touch anything else at that point, I wanted to take a test shot. I was in a room with all lamps turned on and snaped a picture. The picture looked like all the lights were off! It was so damn dark! What happened to my picture? I still need to get used to digital...
You DO realize that an exposure is made up of ISO, f/stop, and shutter speed? Just like in film days (except you were stuck with one ISO for the entire role of film)
Just telling us that the ISO was 100 and the shot was dark tells us NOTHING.
You could easily get a dark shot at ISO100 outdoors too! (ISO100, f/22, 1/8000s would probably do it)
01-09-2011, 03:44 AM   #27
timh's Avatar
Tripod for things that don't move, that's the general rule for best quality. Very easy to follow when you're indoors, sometimes a bit of a pain outdoors.
Try the watch shot again, tripod (or some sturdy support), ISO 100, A mode, F11. Use the 2 second timer.
01-09-2011, 07:58 AM   #28
Ira
QuoteOriginally posted by JeffJS Quote
Gretsch 6120DSW.. From my 1
Hijack alert:
A BIGSBY!
01-09-2011, 09:16 AM   #29
Frogfish's Avatar
1/15 Exposure
ISO 100
With the K7 you can easily use 200 or 400, when pressed I go to 800 to help me keep the shutter speed and aperture I want, and in extreme circumstances, with the K7, even to 1,600 - never more than that as otherwise they are unrecoverable in PP. With the K7 at 400, 800 & of course 1,600 you need to have good noise reduction software to easily erase the noise. A simple job and as a student you'll get great discounts on one of the numerous excellent software programs out there !
You said you opened up the aperture .. to what & from what ?
I shoot in M mode roughly 90% of the time and - depending on what I'm shooting and conditions of course - usually start with 1/180 or faster, ISO 100 or 200 and an aperture of between f2.8 and f5.6 for most subjects (I like a nice narrow DoF for most subjects) obviously this will end up at around f8 - f11 for some subjects.
A good place to start with the K7, if you are not sure, is by pressing the green button to see what the camera says ... though I find this almost always has too slow a shutter speed it does give a good starting point.
01-09-2011, 11:08 AM   #30
Focused in front of the watch I think with the result that only the winder is anywhere near sharp, and it's only vaguely sharp. It looks like everything from the winder to the bottom of the frame is in focus.
I'm also not keen on the fold in the red background and the other bits of whatever there.
Generally speaking it's also underexposed, unfortunately you have those very bright highlights that would be even worse if the rest was correctly exposed. A curves adjustment in post-processing can help with that, but arranging the lighting so you can expose correctly in the first place helps even more.
camera, pentax help, photography, picture
Misc Playing in manual mode.. Harish Hegde Post Your Photos! 5 07-26-2010 08:39 PM
My start in manual mode matze_1 Post Your Photos! 1 05-04-2009 11:47 AM
Wireless in Manual Mode...Help! dminott Pentax Camera and Field Accessories 2 04-04-2009 07:23 PM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
Manual Mode Help Please-K10D GerrieDup Pentax DSLR Discussion 7 04-16-2008 01:17 PM
All times are GMT -7. The time now is 03:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
