01-11-2011, 11:33 AM   #1
Tips shooting with a manual focus lens?
I have a 50mm 1.2 manual lens that I'm using occasionally on my K7 primarily at 1.2.
I find it difficult to focus. I typically turn the focusing ring until I get the beep or the focus indicator in camera. But often I find that the focus wasn't all that great...
I realize that at that aperture I have a very narrow depth of field, but through the viewfinder, I find it very difficult to just sharpness of focus.
Advice?
Thanks,
Ken
01-11-2011, 12:21 PM   #2
The Godfrey Method
QuoteOriginally posted by Javaslinger Quote
Advice?
Thanks,
Ken
Ken: I'm going to paste the instuctions for a series of exercises I found incredibly useful. These come from a helpful poster over at dpreview by the name of Godfrey. I used to just link it but due to the stupid site wars I can no longer do that so I'll just paste the whole thing here. Note that the exercises are time consuming and boring. But they work. I worked with them for about 2 or 3 weeks before I started started to see significant improvement but there definitely was improvement. So stick with them.
THE GODFREY METHOD
]BrettRTurner wrote:
Godfrey, are there any tips you can write down and tell us? Or is
this just one of those things you can teach in person but not write
down?
It's much easier to teach focusing in person. Writing up a procedure to do it is tedious. Happily, with a digital camera, it is easier to practice without wasting a ton of film in the process.
Here's a short sequence to experiment with:
- Start easy: Pick a medium focal length lens, like 50-70mm, and preferably a fast lens. (you can do it with a zoom set to this focal length too.
- Place a target about 2m away, separated from foreground and background. The target should be something with some surface texture to work with, or something with a mix of 6, 9, 12, 14 and 18 point font on it. Light it adequatelly for a wide open aperture and short exposure time (like 1/200 second). Lock in the exposure manually so it cannot vary on you.
- Get comfortable with the camera and set it to MF mode.
- Twist the focusing ring from infinity to closest focus at a medium speed. Then the other direction after a short pause. And again and again. Do it slow enough that you can watch the focus transition from blur to sharp to blur, but fast enough that the transition to critically sharp "pops" for a moment as you turn. OBSERVE the focus transition carefully, over and over again. Get a feel for how much time/how much angular displacement of the focusing ring causes how much focus transition to occur.
The trick is to look at a subject and know the lens well enough to turn the focusing at the speed which makes the sharp moment pop, and be able to stop PRECISELY at that point.
- Start trying to achieve that point of focus ... only turn in one direction and try to stop just once, make an. exposure. DON'T look at it immediately on the LCD ... it helps if you turn off the review function. You want to repeat from close limit and from infinity ten times each.
- Then download the image files to your computer and sort them into frame order. Look at them, one at a time, at 1:1 pixel resolution and mark down which are in focus and which are slightly off. Try to remember for each one what you felt as you stopped and made the exposure.
Repeat this exercise until you get nine frames sharp. Then repeat it again doing 20 frame sequences until you get 19 frames sharp. Do as many as you can but DON'T keep going until you get tired, stop and take a break for a little while. The point is to plant in your finger and eye memory how fast to turn the ring and how to stop instantly when you see the point of best focus, just once.
- Once you're doing sequences of 20 shots and getting them all in focus, double the target distance with the same lens and do the same exercise over again. Once you get 20 out of 20 with that repeatedly, you can double the distance again. It gets faster as you go along. By the time you get there, you should set up two more targets so you have three ... 2, 4, and 8m ... and do a couple of sequences where you focus on each one at a time ... put it in the center of the frame so you know which your focusing on ... and do the same sequence of 20 until you get them all in focus through the sequence repeatedly.
So now you know what it's like to focus that lens quickly and reliably, with your eye alone.
- Change the lens to a shorter focal length (say 28 to 35mm). Start at the beginning but use 1.5m as a starting point. Same rig, same target, different focal length ... the shorter the focal length, the more subtle the focus transition is to observe.
- Keep doing the sequences with shorter and shorter lenses until you get to the shortest lens you have. Realize that when you get down to the 18-20mm range, you have to accept either a slower pace or a few more erroneous focusing frames to "finish" a sequence.
This kind of skill does not take exceptional eyesight; it takes the ability to see the motion of the focus transition 'stop' or pop for an instant and the muscular ability to stop turning the focus ring precisely at that instant. I've been able to get perfect critical focus using it even when my glasses were covered with guck after a hot session on a sweaty day or I dropped them and could not stop taking photos for one reason or another. All you're looking for is that point of "pop" in focus as the image moves a tiny bit, and to stop your fingers at that moment, you're not trying to see the details.
I'm sure that if you go through this exercise with calm motivation, you'll find your manual focusing reliability improve ten fold in a day. I've been doing this so long and with so many different cameras that it just seems to come naturally to me. First thing I do whenever I fit an unknown lens to my camera is switch to MF and just rack it in and out from infinity to close limit focus a couple of times to "calibrate" my eye and fingers. Within a few moments of that, I'm ready ... I rarely get a bad focus, if I bother to look through the viewfinder and focus at all ...
Which is another story.
Godfrey
NaCl(hope they help)H2O
01-11-2011, 12:24 PM   #3
Good teaching info there.
01-11-2011, 03:01 PM   #4
Mike Cash's Avatar
1.2? Or 1:2?
Either way, you'll have better results if you swap the focus screen for one optimized for manual focus; the stock screen sucks.
01-11-2011, 04:10 PM   #5
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Mike Cash Quote
For me it's as Mike says, a Katzeye and plenty practice.
01-11-2011, 05:35 PM   #6
Ira
1.2? Or 1:2?
You took the words right out of my drooling mouth.
01-11-2011, 06:37 PM   #7
Ignore the beep and the light. Don't look at the whole scene, but concentrate on one small spot where you want to center focus. Go past focus both ways, then slowly to optimal focus. Watch your spot carefully. When it sort of pops with higher contrast, you're "spot on," as they say.
camera, focus, pentax help, photography
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
Tips for shooting lens comparison shots you like to share? cheekygeek Pentax SLR Lens Discussion 5 01-21-2010 05:55 AM
When Shooting a manual lens with tele extender and SR on wll Pentax DSLR Discussion 10 06-24-2009 09:56 AM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
Manual Focus Tips menappi Photographic Technique 26 12-08-2008 06:08 PM
All times are GMT -7. The time now is 01:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
