Hello pentaxians!
I am a long time lurker of these excellent forums, now decided to post a question because I cannot seem to be able to find an answer.
It is an old thread but it is the same lens and the same issue so I figured I should not open a new one.
Similar to the OP's case, I just received an SMC A 50mm f1.4 and noticed somewhat loose focusing ring feeling (not as tight/dumpened as my SMC M 50mm f1.7) and also a little play.
I recorded a video to show the amount of play:
lens play - YouTube
I cannot explain much the tightness of the focusing ring, since I have only experience with the M f1.7 version which is really tight and it is hard to put in words (it is subjective after all). But is this amount of play normal? Is this something I should be worried about?
Appreciate any input!
Thank you very much!
