01-12-2011, 12:01 PM   #1
will the lens fit?
im looking into a takumar super 50mm 1.4 lens but i dont know if it will fit my pentax k-m?? does my camera have M42 screw mount or the bayonet? or neither?
01-12-2011, 12:06 PM   #2
sterretje's Avatar
Yes, it will fit using an adaptor
Pentax : PentaxWebstore Mount Adapter K(35m m Screwmount to Bayonet)
Regarding 3rd party ones, search this forum for issues and solutions
01-12-2011, 12:13 PM   #3
KxBlaze's Avatar
Your Km I'm pretty sure has a KAF mount (which is a Bayonet) and as the previous poster said, that lens will fit but with a K to M42 adapter.
01-12-2011, 12:52 PM   #4
Ira
That's a great lens, so get that adapter!
01-12-2011, 09:09 PM   #5
When buying an M42 to K-mount adapter, be careful. You can't go wrong with the genuine Pentax brand adapter.
There are third-party adapters that are less expensive. Some work, some don't. There are basically, two designs. The genuine Pentax and others like it, fit completely within the k-mount opening of your camera. These adapters add no additional thickness to the camera, and allow the lens to focus to infinity, as it should.
Then, there are other third party adapters that have a large flange that sits outside the lens mount opening, between the lens and the camera. This additional thickness prevents the lens from focusing to infinity, which is okay if you intend to use the lens only for macro or closeup work, but not for general use.
Third party, no infinity focus:
M42 Lens Adapter Ring for Pentax K mount K200D/K110D - eBay (item 170448540824 end time Jan-15-11 05:01:40 PST)
Third party, with infinity focus:
Pentax M42 42mm to PK K Mount Adapter Infinity focus - eBay (item 250638610334 end time Jan-19-11 10:54:03 PST)
Genuine Pentax adapter:
Pentax M42 Screw Mount to K Mount Adaptor, New Genuine - eBay (item 230569904341 end time Jan-16-11 19:00:57 PST)
Some will argue that the only adapter worth using is the genuine Pentax unit. As I said, you can't go wrong with that one. I have a third party adapter that works just fine on my K10D, so some third party adapters will work. Some can be difficult to remove.
camera, lens, pentax help, photography
Will this lens fit Pentax K-x newyorker Pentax DSLR Discussion 26 10-04-2010 01:23 PM
Will this lens fit my kx? 4ngi3 Troubleshooting and Beginner Help 13 06-30-2010 11:33 AM
Oh no! I got a lens that won't fit! Ouroboros Troubleshooting and Beginner Help 15 03-23-2010 08:12 AM
Will this lens fit my kx ??????? spanky66d Troubleshooting and Beginner Help 7 02-18-2010 03:23 PM
Old K mount lens would not fit! dbh Pentax SLR Lens Discussion 18 12-13-2008 09:45 PM
All times are GMT -7. The time now is 05:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
