01-13-2011, 06:56 PM   #1
GoldenRGuy's Avatar
K7 Rear Dial
Has anyone had trouble using the rear dial in any of the non auto modes? I've been trying to use M and can't get the rear dial to change anything. Reset to factory settings and still not working.
Thanks!
01-13-2011, 08:49 PM   #2
Canada_Rockies's Avatar
Are you attempting to use the rear dial with a lens without the "A" aperture position, or with the aperture dial set to a number rather than the "A"? Other than that, I cannot think of anything that would cause this particular problem.
01-14-2011, 01:28 AM   #3
QuoteOriginally posted by Canada_Rockies Quote
Other than a defective or dirty dial contact. It has happened but usually there is Some response. For now, I'm going with your suggestion until we learn otherwise.
01-14-2011, 01:44 AM   #4
Frogfish's Avatar
I shoot 90% in M and have never had this issue. I hope it's one of the potential causes above and that you can correct it without returning it for repair.
01-14-2011, 06:59 AM   #5
Lowell Goudge's Avatar
what is the status of the battery?
I found that when I pushed the battery to the end of charge, the camera did not recognize properly the thumbwheels. it would still work but the thumbwheel reaction was eratic at best.
I think the pressure to have long battery life has pushed pentax to have the dead battery indication a little lower in voltage than the correct operating threshold of the thumbwheels (OOPS)
01-14-2011, 03:19 PM   #6
GoldenRGuy's Avatar
Battery is full.
---------- Post added 01-14-11 at 05:22 PM ----------
So I went to the camera store and they told me that the K7 does have a history of rear dial problems. He checked my camera and it's definitely the dial. So, has ordered in another K7 and will test it's dial. If the dial works will give it to me and send mine to Pentax for repair. Great service! If the 2nd one fails, it will have to be repaired, but then will be as good as new!
01-15-2011, 07:37 PM   #7
You might have a faulty e-dial control board in your camera. I had a similar problem with my K-7, and Pentax replaced the e-dial control board.
01-29-2011, 11:39 AM   #8
Had the same problem with my new K-5. Rear e-dial would be erratic and unresponsive. It was suggested in another forum to turn the dial backwards and forwards for a few minutes with the camera switched off. Tried this and problem solved - the dial is now working perfectly. Not sure how permanent a fix this is but if it saves sending the camera off for repair it's good enough for me.
01-29-2011, 02:03 PM   #9
Mike.P®'s Avatar
QuoteOriginally posted by Johnny B Quote
I had the same problem with my front dial on the K-5.
Tried the back/forwards trick and it worked for a while but then went back to being erratic.
Had to send the K-5 back because of staining, new one arrived yesterday and the dial is absolutely perfect.
pentax help
K10D Rear E-dial Won't Work NiftyFifty Troubleshooting and Beginner Help 2 07-21-2010 03:26 AM
K-7:Rear e-dial not working correctly bulacawa Pentax DSLR Discussion 11 05-29-2010 04:13 AM
Rear Dial not Working Rondec Pentax DSLR Discussion 4 04-05-2010 02:58 AM
K10 Rear Dial Problems Rondec Pentax DSLR Discussion 2 07-22-2009 09:37 PM
K20D Rear E-Dial Squeak? nah Pentax DSLR Discussion 4 04-07-2009 01:44 PM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
