01-15-2011, 12:33 PM   #1
Spotmatic F shutter speed Dial stuck on '4'
Everything else works, Including setting the ISO. Will not move in any direction. Honeywell pentax service manual says that to remove the dial I would have to set it to B, which is currently impossible. Happened in normal use indoors.
Any help or suggestions appreciated.
01-17-2011, 05:17 PM   #2
Ole
Ole's Avatar
This doesn't sound like a fix-it-yourself problem. Eric at Pentax Camera Service can most likely fix it at a reasonable cost. Eric has helped many users on this forum and is highly regarded.
If you want to go the replacement route I have good experience buying used equipment from keh.com in the US and vintagevisuals.com in Canada.
BTW, I'm not affiliated with any of the above mentioned outfits.
pentax help, spotmatic f shutter
Stuck dial on my Program Plus filmamigo Pentax Film SLR Discussion 4 03-14-2011 05:44 AM
Help! Mode Dial stuck? chriiisty Troubleshooting and Beginner Help 6 03-14-2011 01:05 AM
Stuck rear e-dial on an *IstD body Keith Wignall Pentax DSLR Discussion 6 11-24-2009 05:29 AM
Pentax SV with stuck shutter speed dial blackplanet Pentax Film SLR Discussion 0 10-30-2008 03:23 PM
Rear e-dial stuck on K10D Groundloop Pentax DSLR Discussion 11 03-14-2008 11:22 AM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
