01-16-2011, 07:57 PM   #1
PH-RBG folds into DAL 55-300mm?
I recently bought a PH-RBG equivalent lens hood for my DAL 55-300mm lens. It seems you have to take the hood off to store the lens. Does this hood fold in or slide in to the lens for easy storage?
Thanks,
01-16-2011, 08:08 PM   #2
boriscleto's Avatar
You can turn the shade around and store it on the lens.
01-17-2011, 05:24 AM   #3
Nowhere Matt's Avatar
Yes as Boriscleto mentions many people often simply turn around lens hoods and screw them on in reverse. Takes up a little less room that way and the hood is still kept with the lens when you need it.
01-17-2011, 08:16 AM   #4
Thanks, to both, for the reply.
01-17-2011, 02:33 PM   #5
GerryL's Avatar
It would look something like this with the hood reversed on the lens for storage.
01-19-2011, 06:48 AM   #6
Thanks for the pic.
01-19-2011, 08:02 PM   #7
SpecialK's Avatar
If you buy a lens cap that pinches together in the center, like Tamron's, you can remove the cap with the hood on. You could then store it vertically with the hood on and the mount down, if you had the correct case :-)
camera, hood, lens, pentax help, ph-rbg, photography
55-300mm DA vs DAL Gregor Pentax SLR Lens Discussion 35 10-05-2013 07:22 PM
For Sale - Sold: DAL 18-55mm and DAL 50-300mm (US) happygui Sold Items 6 08-25-2010 01:22 PM
What is the Diff b/w DA 55-300mm & DAL 55-300mm ajaya Pentax SLR Lens Discussion 6 05-14-2010 07:14 AM
All times are GMT -7. The time now is 05:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
