Originally posted by tpx60s NaCIH20 I see what you're saying. I pulled the lever ( the one with the little circle thingy)and only the lever on the inside of the body moves up and down but the mirror does not move. Is that fixable?
Sgtkashim- I think that I was just describing it wrong to you.
Alright, so here's the test I did, step by step.
Power on, menu, wrench sub-menu, sensor cleaning. On the Kx it's sub-menu 4. Not sure about the *istDL. You should hear the mirror move at this point. It will sound like the first half of taking a picture.
Remove the lens.
Look into the hole where the mirror usually is. You should see a shiny, greenish/blackish rectangle. That's the sensor. If if looks dull and has 3 fine lines running horizontally, then that's the shutter gate and your shutter is busted. If you still see the mirror (it looks exactly like it does when you swap lenses), then you have a bad mirror lifter or something like that.
If you see anything other than that, someone has pried your sensor off the circuit board... and you're going to need a new camera.
Power the camera off - the mirror should drop down.
If all of this checks out, then you have an electrical problem between the sensor and the card reader. Given that it writes a file, though, the card reader is fine. It also appears to process the file fine, so if the shutter and mirror work, I'd guess the problem is the sensor is fried or physically disconnected.
DON'T DON'T DON'T put it in bulb mode and press the shutter. A live CCD will suck in dust like a vacuum cleaner - static electricity. Also why you should never change lenses w/ the camera on. DOFP will not show you anything - it just actuates the aperture arm.
