OK, I have a more thorough rant about "backwards compatibility" with lenses, it should help you to fall asleep
The first SLR to have TTL metering was the "Topcon RE Super" introduced in 1962.
48 years later, in 2010 I was shooting an event with a "fast" manual lens on my Nikon D40, and I had to meter by guessing, shooting, then "chimping".
define:Chimping - Google Search
I was shooting in a kinda low light situation with movement, an elementary school graduation on a rather dark stage.
I knew I could get pretty clean files @ ISO 1600, so I wanted to couple that with a 3.5 constant maximum aperture zoom lens.
I had a nice one, Nikon 36~72 f/3.5
http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/eserieslens...ls/36150mm.htm
It was in F-mount, the same as my camera, Nikon has never changed their mount.
But Nikon had disabled the metering of manual lenses in their entry level cameras, presumably to sell more of their expensive "AF-S" lenses. I didn't have enough money for a fast lens that was fully compatible with my camera. The closest lens was :
Nikon AF-S Nikkor 24-70mm f/2.8G ED is about $1400
Or 3rd party option :
Sigma 18-50mm HSM f/2.8 is about $450
Tamron 28-75mm f/2.8 BIM is about $450
But I had the 36~72mm f/3.5 lens (it typically sells for about $40). Aperture 3.5 is often overlooked yet less than one stop slower than aperture 2.8, and when coupled with ISO 1600 I can get the 1/60 shutter speed I need in most any light.
So I did, I shot the event with 5 different lenses and it was OK, but quite a struggle shooting with no meter when things are happening quickly. Afterward I saw that my best shots came from the autofocus lenses that were fully compatible with the camera (18mm f/3.5 AF-S and 35mm f/1.8 AF-S), here are a few samples :
But I think if the camera would have been more friendly towards the manual focus lenses I brought, Vivitar 135/2.8, Nikon 36~72/3.5, and Nikon 75~150/3.5; those shots would have come out better.
I later concluded that limitations built into a camera become inconveniences for the photographer.
I had to suffer that inconvenience on account of Nikon's greed. Nikon wanted me to buy the $1400 2.8 AF-S lens, but I couldn't. My car doesn't even cost that much!
Eventually I went on to study "strobist" stuff :
Zack Arias' OneLight Workshop & DVD
They shoot without a meter all the time, shooting test shots and "chimping". I eventually became a lot more comfortable with the idea of shooting without a meter, or instead using my handheld flash and ambient light meters.
But I never forgot about that graduation, what a hard time I'd had. Not entirely because of my lack of training, but also because of the greedy limitation.
I later also learned the concept of "cropping rather than composing" from a Kelby training video :
Jay Maisel | NAPP | Photography | Kelby Training
So I guess I could have just shot the entire event "wide" with 18mm f/3.5 and 35mm f/3.5, then later cropped. But I did not know that concept back then.
I also plan on buying a 2.8 zoom lens eventually.
But with Pentax I have a choice - I can use the old lenses and the camera fully supports them. While I'm doing that I can save up for the 2.8 zoom lens. I have a choice
That's really why I switched to Pentax
Less limitations means less inconveniences.
OK rant over
In other news the K-X has come in
It's interesting. Immediately I miss the 3rd party battery grip I used to use :
Amazon.com: Targus Digital TG-BGD40 Battery Grip for Nikon D40/D40x/D60: Camera & Photo
but I think I can get used to this small camera, it's not too bad.
So far I've tried manual "M" lenses with it, I've tried manual "A" lenses with it, and AF. Also manual flashes (like Pentax af160sa and Sunpak 933) They all work pretty well.
The Sunpak 933 is an awesome flash for bouncing, I like to bounce behind me to make a nice soft light in front of me :
http://www.3dcamera4u.com/w38121.jpg
Here is a quick snapshot of my little buddy using the 933 bounced behind me, and Vivitar 128/2.8 M42 lens on the K-X :
Here is a shot from Christmas (D40) with a light and umbrella on a stand (a lot of work to set up and move around) :
Here are some shots to compare, also D40 but now with the Sunpak 933 bounced behind me :
To me the results are almost as good as an off camera flash, but much more portable, it's right on the camera!
There is also a great Kelby training video about this from David Ziser called "15 Ways to Improve Your Photography Using On-Camera Flash" :
David Ziser | NAPP | Wedding Photography Lighting Techniques | Kelby Training
Of course using the manual flash bounced is "all manual", "M" on the camera, no auto ISO, aperture controls flash exposure and shutter speed controls ambient light (if applicable).
I learned this stuff from the "Strobist" DVD (OneLight) but basically :
if your subject is too bright, stop down your aperture (ie : from f/8 to f/11). If your subject is too dark open up an aperture (ie : from f/8 to f/5.6).
If you ambient light is too dark slow down your shutter speed (ie : from 125 to 60). If your ambient light is too bright speed up your shutter (ie : from 60 to 125)
So you can shoot and chimp, or you can use a flash meter.
I also got to try the K2000 briefly, and I think the K2000 resembles the D40 more than the K-X does, I found the K2000 to be very simple and nice and affordable LOL
The K-X seems kinda complicated and I'm trying to get the hang of it.
I bought the K-X e-book for $11 :
Pentax e-books
and I found a K-X specific guide / blog :
A guide to the Pentax K-x Digital SLR Camera.
And I happen to have a lot of old film gear, nothing stunning or valuable but I like it. Here is everything I have that can be used on my new K-X
That's a lot of choices while I save up for a 2.8 zoom
Here is the lens list :
1. Tele-Astranar 400mm f/5.5, Germany, M42 (Piesker) manual focus, manual aperture only
2. Vivitar 28~210mm f/3.5~5.6, Japan, K-A (Chinon?) manual focus, auto and manual aperture
3. Promaster 70~210mm f/4.5~5.6, Japan, K-A (Tamron?) manual focus, auto and manual aperture
4. Takumar 28~80mm f/3.5~4.5, Taiwan?, K-A (Pentax) manual focus, auto and manual aperture
5. Vivitar 135mm f/2.8, Japan, M42 (Komine) manual focus, manual aperture only
6. Pentax-DA L 18~55mm f/3.5~5.6 AL, Vietnam, KA-F (Pentax) auto focus, auto aperture only
7. JC Penny 28mm f/2.8, Japan, M42 (Makinon?) manual focus, manual aperture only
8. Sears 50mm f/2, Japan, K-A (Chinon?) manual focus, manual aperture only
9. Industar 50mm f/3.5, Russia, M42 (KMZ) manual focus, manual aperture only
And I'd like to take my gear out to the park and take some shots, but it's been super cold here lately, and there is snow all around
So I am hibernating
OK have fun!
Craig
