I'm just not getting this.
I'm pretty sure I understand the
theory behind using the neutral grey to adjust the white balance setting to compensate for taking pictures where there are larger than usual very dark or very light areas. But when it comes to setting the needed WB on my K-x using a grey card, the operating manual is not helping me.
Once I'm in the White Balance screen, I select Manual. But on page 185 the manual tells me to use a
white sheet of paper, NOT a grey card. Surely it's not a matter of either/or. Am I getting mixed up between two different procedures?
And once someone points out what is probably as plain as the nose on my face,
maybe you can also tell me what I'm supposed to do on the K-x to keep that WB setting for the rest of the shoot.
Thanks
