01-24-2011, 09:37 AM   #1
ISO and Auto Mode
I've only been using my K-X in auto pict mode. Today I took some outdoor pics of a house in bright sunlight and snow. I thought auto mode would lower the ISO speed but it didn't-it set it at 1600. When I looked at the pictures on my laptop at 100%, you could see graininess-something I wouldn't think I'd see on such a bright day. I set the ISO to 200, as an experiment, and the graininess went away. When I set the mode to Landscape, 1600 was chosen again.
I'd still like to use Auto mode and would like to get nice shots. Do I always have to fiddle with the sensitivity setting, or can I set a parameter for Auto mode?
Thanks.
01-24-2011, 09:49 AM   #2
Ira
Don't use auto pict mode. Use Av, and select your aperture.
01-24-2011, 10:02 AM   #3
enoeske's Avatar
Or since you want clean images, use Sv, sensitivity mode and set you sensitivity to 200
01-24-2011, 10:28 AM   #4
I would suggest P mode with the ISO set to a range of 100-800 to start. Once you get a handle on things, Av mode is a nice next step.
01-24-2011, 10:35 AM   #5
Thanks, all.
01-24-2011, 10:55 AM   #6
lavascript's Avatar
Right. Auto still lets you set the ISO manually. (On my K10D at least) You had probably set it to 1600 earlier and forgot about it.
01-24-2011, 11:25 AM   #7
sterretje's Avatar
I assume that the follwoing is happening:
If you use the landscape scene mode, the camera will try to use a narrow aperture (high number) to give a deep DOF. To achieve this it either needs to use a slow shutter speed or increase the ISO or a mix of the 2 for correct exposure. The camera might well have choosen a quite fast shutterspeed to prevent camera shake affecting the image and therefore had to crank the ISO to 1600 for correct exposure.
01-24-2011, 12:09 PM   #8
It was very bright and snowy.
I mis-read that previous post about changing the range of the auto-ISO, but wound up finding it myself before popping back on the forum. That abilty to set range is indeed convenient, but I wonder if it will always choose the highest ISO in Auto mode. I found the graininess pretty obvious when viewing at 100%. If I recall, Kodak Tri-ex, or something like that, was considered fast at 400, back in the day.
01-24-2011, 01:14 PM   #9
lavascript's Avatar
It should default to the lowest ISO in auto mode, unless available light dictates otherwise. If you got pics at ISO1600 on a bright, snowy day, it must have been set to 1600 and not auto. If you post a pic, we can look at the EXIF and see exactly what all the settings were and try to go from there.
But also, Auto mode is really not the place to be. Switch one click over to P.
01-25-2011, 05:19 AM   #10
Ok. I'll try P, but the ISO was set to 200-1600.
auto, camera, iso, mode, pentax help, photography
Auto ISO in manual mode yusuf Pentax DSLR Discussion 37 03-10-2012 05:44 PM
K-7: Auto ISO in P mode is finally fixed Edvinas Pentax DSLR Discussion 49 08-18-2009 10:19 PM
k20d auto ISO in TAv mode wiyum Pentax DSLR Discussion 10 08-13-2008 05:18 PM
auto ISO in M mode? not option? Akcelik Pentax DSLR Discussion 4 03-07-2007 05:38 PM
K10D. Bug with Auto ISO in P mode? Edvinas Pentax DSLR Discussion 21 12-30-2006 05:47 PM
All times are GMT -7. The time now is 04:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
